RV.Net Open Roads Forum: Attaching a satellite to the top of a TT
 > Attaching a satellite to the top of a TT
rollindowntheroad
Sebring, FL
Posted: 12/05/20 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Does anyone know of a way I can attach a Dish Playmaker satellite to the top of my TT without attaching it permanently? I am going to be in an RV park for a long a term period. Want to have the satellite out all the time but worried it might get stolen. Is there any way I can attach it to the top of the TT to keep the wind from blowing it off but it would more out of sight? I don't want to attach it permanently.
Thank you in advance for any suggestions.
camp-n-family
London, Ontario
Posted: 12/05/20 10:55am Link  |  Quote  |  Print  |  Notify Moderator
If your rv has a ladder you could get this Ladder mount kit. Winegard also makes a Window mount kit.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
rollindowntheroad
Sebring, FL
Posted: 12/05/20 11:00am Link  |  Quote  |  Print  |  Notify Moderator
I don't have a ladder on the TT.
QCMan
Independent Republic of Horry
Posted: 12/05/20 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
Satellites typically go on top of a rocket. You probably want to attach an antenna to your roof instead.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Gdetrailer
PA
Posted: 12/05/20 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like this?
Bolt it to a 4'x4' chunk of 3/4" plywood (paint the plywood to seal it from the weather)then sit it on top of your trailer roof while parked (might need some shims to level it depending on how sloped the roof is).. Doubt most winds will ever move that..
rollindowntheroad
Sebring, FL
Posted: 12/05/20 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yes that's the exact dish I have
Diamond c
West ky
Posted: 12/05/20 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
How does that work for you? I’ve heard conflicting reviews about it. We’ve been thinking about getting one but not sure they are worth the money.
rollindowntheroad
Sebring, FL
Posted: 12/06/20 04:22am Link  |  Quote  |  Print  |  Notify Moderator
Diamond c:. It works great with one issue. I have to connect the cable directly to Wally through the entry door. For some reason it will not work when the cable is connected to the satellite port on the outside of the TT. I have tried to connect it to both the satellite and cable port on the outside of the TT but it won't work. My TT is a 2018 Prime Time Tracer Air. I have read where others have had the same issue.
MKirkland
Washington state
Posted: 12/07/20 04:28am Link  |  Quote  |  Print  |  Notify Moderator
I have the tailgater and had the same connection problem. I really got tired of running the cable through the window. There is a way to bypass the cable up in the port with better better cable. I elected not to do that. Instead, I had my maintenance person just run a connection from the outside of the trailer to the inside, close to where the receiver is. It works great and there is a kit for doing it.
rollindowntheroad
Sebring, FL
Posted: 12/08/20 03:32am Link  |  Quote  |  Print  |  Notify Moderator
MKirkland: Where do you get the kit?
