RV.Net Open Roads Forum: Attaching a satellite to the top of a TT
 > Attaching a satellite to the top of a TT
1ed
Northern California
Posted: 12/08/20 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
Dish receivers have to be DIRECTLY connected to the Satellite Antenna.
All of the connections on the trailers go thru a splitter that makes the receiver not work.
What I did was use the outside TV connection where the TV is mounted and took that connection apart and used one of the cables for a direct connection for the receiver. Took about 15 minutes to complete.
* This post was edited 12/08/20 10:53pm by 1ed *
MKirkland
Washington state
Posted: 12/09/20 05:11am Link  |  Quote  |  Print  |  Notify Moderator
I got the kit from the RV maintenance people. It's not fancy, just a bar that goes through the wall of the trailer with a. Plug in on each end for coax. The outer plug in has a screw on for the weather when you are not using it. Trailer is in storage now so I can't take a picture.
Lynnmor
Red Lion
Posted: 12/09/20 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Some trailers have a dedicated satellite connection with no splitter, if there is just one cable connection, it may or may not have a splitter.
rollindowntheroad
Sebring, FL
Posted: 12/09/20 11:53am Link  |  Quote  |  Print  |  Notify Moderator
On my trailer there is an outside connection labeled Satellite and another right next to it labeled Cable. I've tried connecting the satellite cable to both and it doesn't work on either one. Don't know if there is a splitter or not, just know that it doesn't work. On the inside of the trailer there is a connection for the antenna that's on the roof, that works, as I used it prior to getting the satellite. There is another connection on the wall, it's not marked. I assume it's for either satellite or cable.
I'll have to check on getting the kit to put in the wall. Would be so much easier than running the cable through the entry door.
MKirkland
Washington state
Posted: 12/09/20 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder if that sat connection can be corrected. I had a professional put in the kit, but maybe your problem might be an easy cable fix.
Gdetrailer
PA
Posted: 12/09/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Anything is possible if you toss enough money and time at it.
From HERE sounds like it is a common problem.
The connections on the outside may be mislabeled if you have on marked CATV and One SAT, try switching connections you are using.
If you have a BOB (box of buttons) you could disconnect the CATV coax from the box and see if you can use the CATV jack..
Or the simplest and low cost way, just run a short separate dedicated coax from your receiver to a new dedicated Sat jack on the side that you install.. Yep, in this case you will need to drill through and place a jack on the wall but at least it will be done and working.
Unless you have a hundred feet of coax, one extra coax connection won't hurt operation at all.
badsix
north bend or.
Posted: 12/10/20 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
[image] i did this, i can store the pole in my storage compartment and it also fits on the front if the satellites are that way. i can lock it down to the bumper with a small cable.
Jay D.
CavemanCharlie
Storden,MN
Posted: 12/11/20 09:35am Link  |  Quote  |  Print  |  Notify Moderator
badsix idea looks like a good one. The picture is to big but, the moount looks good.
badsix
north bend or.
Posted: 12/15/20 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Can i edit and make the picture smaller? i have a socket on the front so if the satellites are in that direction.
Jay D.
Diamond c
West ky
Posted: 12/15/20 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Do I understand correctly that the satellite must have an unrestricted view of the southern sky? We have stayed in a few places that that would not work, but if it was mobile it would.
