RV.Net Open Roads Forum: Class A Motorhomes: Newmar response
fuzzyface
Polk City, FL
Posted: 12/06/20 11:21am Link  |  Quote  |  Print  |  Notify Moderator
A quick search on Amazon turned up this result:
https://smile.amazon.com/s?k=tone+wire+tracer&ref=nb_sb_noss_1
Linda and Mike Kruzin' in a Kountry Star
robatthelake
Vancouver Island
Posted: 12/06/20 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Any luck?
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
MountainAir05
New Mexico
Posted: 12/06/20 11:56am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, faster than I.
Gene
dougrainer
Carrolton, Texas
What do you mean 5 Junction boxes? Are you talking about the Freightliner/Sparten black boxes? If so, these have NOTHING to do with the Ignition key activated Dash accessories. The system that activates the Newmar Dash Accessories is NEWMAR installed as well as the Solenoid/relay. On your year model, you should have a Plexiglas covered Fuse/Relay panel above the Genset. This is the area of these controls you need fixed. HOW CAN YOU STATE RELAY'S/SOLENOIDS HAVE BEEN CHECKED AND ALL OPERATE?. Obviously the Acc solenoid is NOT operating. Either it is bad(stuck open) or the power wire to it has a blown fuse. The fuse is usually at the drivers area inside fuse block(frtliner or sparten). SOME models the Dash Chassis Fuse block is also inside that plexiglas covered panel. Doug
Tom/Barb
Oak Harbor, Wa
Posted: 12/06/20 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Common relays are not brain surgery. they are easy to show works or not, these all work when tested
the Newmar module you speak of was replaced.. simply ... it is not being turn on.
there are two 10 gauge wires labeled battery and ignition the battery shows 12 volts when the key is turned on. the ignition never shows 12volts either position Acc/IGN. the diesel runs fine.
Tom/Barb
Oak Harbor, Wa
Posted: 12/06/20 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Gene
Thanks guy/gals
It is on order.
Now I must learn to use it [emoticon]
MountainAir05
New Mexico
Posted: 12/06/20 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
Gene
Thanks guy/gals
It is on order.
just a tip. Find the wire you want to trace and ensure you disconnect the power to the circuit 12 volt or AC. Then connect one wire to the wire tracing and the other to a ground. You will be surprise how you did without one.
Tom/Barb
Oak Harbor, Wa
Posted: 12/06/20 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Home-depot shows one,, not in this store.
ordering one from Amazon [emoticon]
Is there a good one or ?
Tom/Barb
Oak Harbor, Wa
Posted: 12/06/20 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
I know the area in the nose cap, there are 3 boxes, which relay do you think is at fault.
MountainAir05
New Mexico
Posted: 12/06/20 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
I only use Fluke so can't help on any others.
