RV.Net Open Roads Forum: Class A Motorhomes: Newmar response
dougrainer
Carrolton, Texas
Posted: 12/07/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Page 143. For Frtliner. Next page for Spartan. Is this what you have 2000 is about the same as 2002.
https://newpar.newmarcorp.com/instance1Env99NEWMAR/html/images/2002DSDPOG.pdf
Tom/Barb
Oak Harbor, Wa
Posted: 12/07/20 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
that's the same as ours
Ours is a 2000mountain aire.
Spartan
the relays I know about are labeled ACC# 1 and ACC#2
* This post was edited 12/07/20 02:39pm by Tom/Barb *
Blaster Man
Posted: 12/07/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
My experience is that the tech side of the house will not call back. You have to call them and wait in line until they get to you. They all like to say, "call, leave us a message and we will call you back."
2014 American Eagle
Tom/Barb
Oak Harbor, Wa
Posted: 12/09/20 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Tom/Barb wrote:
MountainAir05 wrote:
fuzzyface wrote:
A quick search on Amazon turned up this result:
https://smile.amazon.com/s?k=tone+wire+tracer&ref=nb_sb_noss_1
Thanks, faster than I.
Gene
Thanks guy/gals
It is on order.
Now I must learn to use it [emoticon]
I received the Tone Generator yesterday,,, what a cool tool.
MountainAir05
New Mexico
Posted: 12/09/20 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Gene
Thanks guy/gals
It is on order.
Did you fine your fault
Tom/Barb
Oak Harbor, Wa
Posted: 12/09/20 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Gene
Thanks guy/gals
It is on order.
No,,
MountainAir05
New Mexico
Posted: 12/10/20 07:48am Link  |  Quote  |  Print  |  Notify Moderator
go from one of the accessories and tone back to the relay /switch
If that fails, pull the fuse and power from the relay side toward the relay. Voltage should show up downstream. Relay will not work due to no ground trigger.
The way I read your statement is power flows from switch to relay but relay will not contact. If power is at relay then the ground is not working, but that could come from the accessories panel back to relay or from the switch. I no longer have my books for your RV. I sold mine some years back and all that stuff went to the new owner.
If you jump power from relay then does the accessories start working.
* This post was edited 12/10/20 08:38am by MountainAir05 *
Tom/Barb
Oak Harbor, Wa
Posted: 12/10/20 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Thank You
I'm working on it..
