RV.Net Open Roads Forum: Do It Yourself Modifications and Upgrades (DIY): Fridge Swap-out
MPI_Mallard
Morpeth Ontario,St. Cloud Florida
Posted: 12/06/20 06:56am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2012 Forest River Cedar Creek 36CKTS that has dumbetic four door rv fridge that I want to replace with a residential fridge with an ice-maker like my other CC Daydreamer has. My questions are,,,
-has anyone done this and how did it go,
-as the fridge in this fiver is elect/propane and only has one 12V battery and my Daydreamer with the residential has four 6V batteries can I assume the existing converter and battery won't support a residential fridge?
-whatever other things I might not expect,
Thanks in advance!
Red Green: Be generous with the duct tape, you
know; spare the duct tape, spoil the job.
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Bl├╝cher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
pianotuna
Regina, SK, Canada
Posted: 12/06/20 11:45am Link  |  Quote  |  Print  |  Notify Moderator
The converter has not much to do with a residential fridge.
Regards, Don
MPI_Mallard
Posted: 12/06/20 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
I wasn't clear, we bought this trailer to leave on our lot in Florida so it takes a three day trip down,,,,
pianotuna
Regina, SK, Canada
Posted: 12/06/20 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
The biggest question is how to get the new fridge in, and the old one out.
Boon Docker
Posted: 12/06/20 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks in advance!
The converter is not an issue.
If boondocking, one battery running an inverter will not work unless you want to run a generator every day to charge up that single battery.
coolmom42
Middle Tennessee
Posted: 12/11/20 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
If you are plugged into 120 V, the converter will not come into the equation, anywhere, relevant to the residential fridge. You will be getting 120V directly from shore power, no battery or converter involved.
The only time the converter comes into play is when you are plugged in, or running a generator, and the converter is charging the battery and powering any 12V items.
If not plugged into shore power, you will need a battery bank and inverter large enough to supply 120V to the refrigerator. So what you need is a battery system large enough to power the fridge during your drive time. Whether or not your battery will do that, depends completely on the capacity of your battery, and the power demand of the fridge. So you have to crunch some numbers to figure that out.
In your shoes, I would get the fridge cold before you leave. Fill up some milk jugs 3/4 with water and freeze them at home, or some other form of block ice. Prechill the other contents of the fridge. Load it up and open it minimally. Maybe take a small cooler for drinks, etc. With this setup the fridge will not run very much and the demand on your battery while driving will be greatly reduced. When you plug in at night, stick the semi-melted ice containers back in the freezer, and move them to the fridge in daytime.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Veebyes
Posted: 12/12/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
From the added info in your second post you are needing 120VAC for the ferry to FL.
There are two solutions. Do nothing. A fridge does not go hot the moment that it is unplugged. Assuming that you will be using CGs each night during the ferry the fridge will chill down each night. Keep the doors closed all day to lose as little chill as possible.
Second option is installing an inverter to run the fridge on while travelling. The TV may or may not keep up with the draw of the inverter but starting with a charged battery overnight the inverter will give some hours use before the battery goes below minimum voltage that the inverter needs. Be sure that the inverter is feeding nothing but the fridge. No other draws.
An engine turning 1800rpm plus at highway speeds should be producing maximum charge to the battery however the issue is long thin wires to the trailer battery which produces VD & a low charge rate.
2007 Alpenlite 34RLR
MrWizard
Traveling
Posted: 12/13/20 11:56pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe the easiest most efficient least troublesome way, would be to duplicate the setup that is in the other dreamer tt
Same or similar fridge Combo inverter-Charger batteries wiring
Make a list, take pictures of everything, try to obtain all the same components, possible it might cost more than hand picking the items needed, the number and type of batteries is a major factor in correct operation of inverter and fridge, one battery is Not going to cut it! For a residential fridge Install, unless you always use campgrounds with shore power hookup, and the fridge power Via inverter is ONLY during transit, then one battery might work, since the TOW vehicle can supply some bit of power to the tt battery while in motion
* This post was edited 12/14/20 04:06pm by MrWizard *
I can explain it to you.
But I Can Not understand it for you !
1997 F53 Bounder 36s
