RV.Net Open Roads Forum: Travel Trailers: Bad smell when running heat
 > Bad smell when running heat
dd_duncan
Kennesaw,Ga
Posted: 12/07/20 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Hello All,
My fiancée and I just moved into our travel trailer for full time use. It is a 2016 forest river Cherokee limited 33’. When running the heat we are experiencing an awful smell. The best way my fiancée has found to describe it is “old farts” (LOL). We’ve been running the heat for about a week and a half now and it has not gone away. It’s not a gas leak because we had one (now resolved) and it’s a different smell. Could I possibly need to clean out the ductwork or service the furnace? Any tips would be greatly appreciated as I’m new to the camper world and am not sure how everything works. Thank you in advance!
Lynnmor
Red Lion
Posted: 12/07/20 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Yes, clean out the duct work. You may be able to inspect much of it with a flashlight and mirror after removing grilles. If you can replace flexible ducts it might be easier than trying to clean them. I hope you don't find a deceased rodent in or around the heating system. Video
kellem
Shenandoah valley,VA
Posted: 12/07/20 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Have you found mice droppings in the trailer ?
Mice infestation will leave a permanent unpleasant odor and is exasperated when they take up residency in the ductwork and furnace....I know.
bukhrn
Lanexa, Va
Posted: 12/07/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Few things smell worse than dead mice in the ductwork. [emoticon]
2007 Forester 2941DS
2014 Ford Focus
routeforty
ohio
Posted: 12/07/20 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Also agree on mice infestation. I had same thing on my last trailer. Ended up replacing the ductwork. Not the easiest job in the world, but doable even for novices. I bought a box of dryer vent(the silver foil flexible type). Pulled the old out and put the new in. When I took each vent run off of the furnace I could check somewhat the inside of the furnace where I found some droppings and a partial nest
which I vacuumed out and cleaned the best I could with clorox. Im sure there are some youtube videos for tutorials. The hardest part is the cramped spaces you must work in. Just remember where the old was, and put the new in the same places. You can do it!! The old that I took out went immediately into the trash. Just had a very,very faint odor in the trailer after that. Gary
2018 coachmen leprechaun class c
dd_duncan
Kennesaw,Ga
Posted: 12/07/20 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone! I’m going to give it a shot this week my next off day from work. Hopefully that does the trick!
profdant139
Posted: 12/07/20 09:38am Link  |  Quote  |  Print  |  Notify Moderator
You may be able to hook up a "crevice tool" to your shop-vac. Good luck!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
dd_duncan
Kennesaw,Ga
Posted: 12/07/20 09:44am Link  |  Quote  |  Print  |  Notify Moderator
One more question- is the ductwork mostly on the inside of the trailer or underneath on the outside typically? There’s an access under my oven but other than that and the obvious vents in the floor, I’m not too keen on the location of things. Thanks!
CavemanCharlie
Storden,MN
Posted: 12/07/20 10:08am Link  |  Quote  |  Print  |  Notify Moderator
My TT has a bad smell from the furnace each time I turn it on. It is caused by dust burning off the the plenum and the plenum itself heating up after it has been setting for awhile. But, it doesn't last after a week of constant use.
mr_andyj
Georgia
Posted: 12/07/20 10:17am Link  |  Quote  |  Print  |  Notify Moderator
dead mouse on your plenum.
I really don't know what a plenum is but assume it is the housing enclosing where the flame is, and gets really hot, and if the mouse died on top of it, the mouse gets hot, doesnt burn, but roast and smells. The smell will be blown through the vents.
Is your smell from the vents?
Eventually the smell will burn itself out, like a scented air freshner stick that has expired.
If it is a mouse then you likely have gross mouse droppings and you need to clean it all out. Prepare to take things apart to get to the dropping. Droppings are a health hazard.
