RV.Net Open Roads Forum: Towing: Air Shocks
Search only in Towing
Open Roads Forum  >  Towing
 > Air Shocks
SweetLou
La Quinta, CA USA
Posted: 12/09/20 06:57am Link  |  Quote  |  Print  |  Notify Moderator
BenK wrote:
Wonder if bicycle tire sealants would work on air bags ?
Liquid snot...AKA Green Slime
Why? Usually all leaks at fittings. Just change out
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
APT
SE Michigan
Posted: 12/09/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I would start with WDH adjustment. $20 at a CAT scale. Restore all lost front axle weight. Then reevaluate how much the rear drops and any future steps.
3 Passes of 3 axle weights (truck front, truck rear, TT combined axles)
Truck without any trailer
Truck with trailer without WD
Truck with trailer with WD
You may need to get the last combo multiple times after adjustment.
2017 Subaru Outback 3.6R
pitch
NY
Posted: 12/10/20 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Tuf truk coils. install and forget. No lines to leak no bags to pop
trail-explorer
NM
Posted: 12/10/20 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
jdc1 wrote:
No mention of a weight distribution hitch here? Come on guys.
Come where?
This topic is about air shocks (or air bags probably) and NOT about a weight distribution hitch.
* This post was edited 12/16/20 12:53pm by trail-explorer *
Bob
Posted: 12/10/20 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
Air bags level the truck. They do not increase the truck’s payload.
Blah blah blah....
Posted: 12/10/20 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
Air bags are simply added springs, of course you can carry more weight (payload} with them. Whether other components, such as tires, wheels and axles are up to the task is for you to research.
^This.
Thank you.
Posted: 12/10/20 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
SweetLou wrote:
KD4UPL wrote:
You want air bags, not air shocks. The shock mounts on a truck aren't designed to support weight.
I've had Airlift bags on 3 different trucks. They worked well and didn't develop any leaks in the bags. I had problems with the plumbing leaking but that's not really the bags' fault.
I have had them on two truck and developed the same for air leaks. I would still use them but first choice are Timbrens
Timbrens are also a good option, however more suited for trucks that carry a heavy load consistently or most of the time.
You can install them “low” and they won’t engage until the truck is likely sagged more than you’d like, but great for that occasional heavy load.
Or you can shim them up to engage sooner but sacrifice full suspension travel while traveling light or empty.
Sweet Lou, you must have just had bad luck with airbags as they’re quite reliable and durable.
That said, Timbrens or sumo springs are the 1 and done easy button.
Posted: 12/10/20 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
Heavy duty coils are a great option as well.
Ram 1500s are notoriously “comfortable”. The rest of the truck is pretty tough like any other truck.
AFAIK, same 9.25” corporate rear axle ( the one part of the equation that isn’t easily upgradeable, obviously) that has been in use for about 40 years. Easily capable of running at 4500lbs or so load perpetually, and not near its strength limit.
The rest of the truck save for the springs is good for basically 5klbs on the rear axle as well. Even the stock tires. Although LT tires are much nicer.
Aside from the other numerous Chrysler 9-1/4 axle trucks, one particular old Ram Charger we had, pulled a sizable tandem axle cargo trailer loaded with commercial mowers daily, for years. Dunno how heavy it was, but there was always 4-5 men in the cabin and enough 36-72” commercial mowers and gear to keep them all working.
Your travel trailer won’t break it short of some real extenuating circumstances.
This explanation was not for the OP, but rather for the weight police!
Posted: 12/10/20 10:18pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn’t do air shocks though. You want quality shocks and more capacity and reliability than air shocks will provide.
Inside the springs air bags for light duty support or traditional airbags for the best support. Imo.
Timbrens are solid too but know the limitations I mentioned above.
You can’t make them “disappear “ like airbags.
azdryheat
Tucson, AZ
Posted: 12/11/20 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I used Firestone airbags on my 2500. Worked great.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
 > Air Shocks
