RV.Net Open Roads Forum: Towing: Air Shocks
Search only in Towing
Open Roads Forum  >  Towing
 > Air Shocks
manley
Wichita Falls, TX
Posted: 12/11/20 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
I vote for air bags. Had Firestone’s on previous TV, and then went with Timbrens on this one. Hated them! Replaced with Air Lift, and couldn’t be happier!
2018 F150 XLT FX4 SCREW Ecoboost 3.5L
Hensley Arrow
2017 Open Range Light 272RLS
1320Fastback
Vista, Ca
Posted: 12/12/20 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
The shock mounts are not meant to support weight. Air shocks would be a mistake.
I would get a WDH set up properly, heavy duty coils and if needed air bags to provide just a bit more leveling.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
bguy
The Rock
Posted: 12/12/20 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
I put a set of air shocks on my 2011 Ram 1500. Works fine. I took out the old busted air bags a PO had installed. Don't worry about the shock mounts. They're only designed to counter act the weight of the truck through the shocks after all.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
trail-explorer
NM
Posted: 12/16/20 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
DHamm20 wrote:
What do you recommend for air shocks?
NONE. NOTHING. NADA.
Bob
mkirsch
Rochester, NY
Posted: 12/18/20 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Just cut a couple lengths of well casing and jam them in between the axle and frame. Tack in a couple of places with your $89 Harbor Freight welder. No more sagging.
 > Air Shocks
