RV.Net Open Roads Forum: Truck Campers: Jack issues
 > Jack issues
silverbullet555
Boise
Posted: 12/07/20 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Well it was bound to happen. Put the camper on the truck back in September for hunting season. Went to take it off the other day and the rear Reico Titan jacks don't want to do anything when I operate them.
It's late and cold so I will need to look more closely tomorrow.
So, my questions. Is this likely a low fluid issue? I don't see any signs of leaks which makes me doubt that it could be so simple.
If this is likely more involved, is there a better approach than to just buy parts to fix them?
Lastly, how do I get the camper off the truck in the meantime? I'm done for the year, but would like to get the camper off and on to the platform where it sits.
1995 Northland Grizzly 860. 2355 lbs of purple goodness! Sold
2005 Lance 845 - Baby Bertha
2007 Chevy Silverado 2500HD Classic CC SB 4WD
Torklift mounts
Torklift superhitch
Hellwig swaybar and 3500lb helper springs
2002 Cobalt 226 "Baby Blue"
fpoole
PNW and Beyond
Posted: 12/07/20 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
Check the battery in the remote. I've had mind go silent and went knutts for a few days, till dealer thought it might be the battery... If you have a back remote, try that or undo the remote to get the battery and get another 2-3 as backups..
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10ā€™ Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow Nā€™ Go, E-Bike
RS1 Buggy
frank
Pooles website
silverbullet555
Boise
Posted: 12/07/20 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
No remote. Hand pump jacks
notsobigjoe
southeast
Posted: 12/08/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
I had a set of the same jacks on my coachman ranger bu they were called hijackers. Two things did what your describing, low oil and the shaft needed a some new rubber gaskets. Probably not low oil if there is no evidence of a leak but if you never checked them or it's been a while maybe. I'd replace the oil if not leaking and get some new rubber seals. Also the cold affects hydraulics some what. Good luck!
Joe
similar to the set I had but much much older.
https://www.riecotitan.com/hydraulic-camper-jacks/%20Four-Corner%20Mount%20Hydraulic%20Camper%20Jacks%20White
These are the gaskets I'm talking about. I replaced them and they were
like new.
https://youtu.be/5DwpvUwohYA
https://hijackercamperjacks.com/
Sorry if they're not the same...
* This post was edited 12/08/20 07:01am by notsobigjoe *
silverbullet555
Boise
Posted: 12/08/20 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Joe
like new.
Thanks for the insight. I'll check the oil to see if that is a portion of the problem. I intend to rebuild them over the winter. I am sure the fact that the highs are in the 30's right now is a portion of the problem. It is likely impacting seals or oil in some way. Better to happen here than somewhere else.
Maybe it will have to stay on until I get those jacks rebuilt. Not the end of the world and a better solution than dropping it trying to get it off.
notsobigjoe
southeast
Posted: 12/08/20 07:24am Link  |  Quote  |  Print  |  Notify Moderator
silverbullet555 wrote:
Joe
like new.
Great! glad I could help as it was described to me many years ago is that the rubber seals get air in them. This creates a dry rot area and also can freeze and defrost many times until they fail. When I replaced them in all 3 jacks they looked and felt like they were new but low and behold the new set fixed the problem. The fourth jack had obvious deterioration. Broken seals etc... I'll see if I cant find the old pics.
StirCrazy
Kamloops, BC, Canada
Posted: 12/08/20 08:11am Link  |  Quote  |  Print  |  Notify Moderator
cold will do that with the wrong type of oil.. people put what ever in these but transmition oil is the best to use, wont get sluggish when its cold, isnt as hard on the seals doesnt rust out the insides like motor oil and hyd oil will do. I just had mine all rebuilt and got to see the effects of using the wrong oils in them.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
silverbullet555
Boise
Posted: 12/08/20 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
But, they were rebuildable.
There is a bottle of jack oil in the camper so I assume that is what has been put in.
silverbullet555
Boise
Posted: 12/08/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I topped them off with the jack oil and got the camper off the truck. I'll order parts to rebuild them over the winter.
StirCrazy
Posted: 12/09/20 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Steve
mine always had the trans oil that hijacker recomends. the guy showed me a few that were not rebuildable because the owner used motor oil in them. hyd oil works just gets thick with cold and then has issues , other oils attack the seals and dont rust protect that great. I learned a lot of stuff about hydrualic jacks from him (one of the original employs of hijacker who rebuilds them for people out here on the side now that the company is defunct. does pretty any brand of hydrulic jack.
Steve
 > Jack issues
