RV.Net Open Roads Forum: Tow Vehicles: Stale DEF
Search only in Tow Vehicles
 > Stale DEF
Cougarnewbie
Illinois
Posted: 12/08/20 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Because of Covid my F-350 6.7 diesel has been garage kept since February. The DEF tank is full. DEF has a shelf life. Should I be concerned enough to consider draining the old DEF? My first diesel.
Thanks
AL
May All Your On Ramps be Downhill
Old-Biscuit
Verde Valley
Posted: 12/08/20 11:28am Link  |  Quote  |  Print  |  Notify Moderator
Shelf Life ...2 yrs in a SEALED Container
Save bet ---- drain and refill with NEW
US NAVY------USS Decatur DDG31
Owens River Road area, north of Mammoth
Posted: 12/08/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
Always treat a diesel the safe way.
4x4ord
Alberta
Posted: 12/08/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
I've read that the shelf life of DEF is one year, but we buy it in bulk and have stored it for years. Deisel exhaust fluid is naturally clear so if it appears cloudy or colored, it’s likely contaminated or old.
Years ago I bought some jugs of DEF from NAPA and poured it into one of my trucks. When I got to the bottom of the container there was an awful lot of crystals in the bottom of the jug ... so much so that the jug spout plugged off. I left it in the truck and ran the truck as normal without any problems. Apparently bad DEF can cause issues.
* This post was edited 12/08/20 02:08pm by 4x4ord *
2021 F350 SRW Platinum short box 4x4.
B&W Companion
NRALIFR
Truck Camping Out West
Posted: 12/08/20 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
It’s probably OK, but you can get on Amazon and buy an inexpensive refractometer that will tell you if it still has the correct 32.5% urea. Some refractometers can also check multiple fluids, like antifreeze, windshield washer fluid, DEF, and battery acid.
Diesel Exhaust Fluid doesn’t degrade nearly as quickly as people assume. For example, at 86°F, DEF has a shelf life of a year. But, don’t equate shelf life to spoiling like food, as DEF will not “go bad”. It will lose some effectiveness, and the SCR will dose at a higher rate, but it won’t “go bad.” If maintained at a constant temperature, DEF manages to stay good for several months. For example, at 74°F Diesel Exhaust Fluid has the shelf life of 44 months.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
rhagfo
Portland, OR
Posted: 12/08/20 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Well why didn’t you do some day trip driving with it during the summer months?
Lynnmor
Red Lion
Posted: 12/08/20 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
7,000 miles of day trips may be a bit too much.
There is no drain plug for the DEF, that might cost 25 cents, instead you need to siphon it out if you want to replace the fluid.
Huntindog
Phoenix AZ
Posted: 12/08/20 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
It is probably worse than that. My 2011 Silverado had a mechanisim to prevent siphoning. Basically a spring loaded door in the fill line. The Fords are likely the same. I believe it is a Govt. anti tampering requirement.
I had to remove the tank to drain mine.
DEFs shelf life varies a LOT with temperture.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
540 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
Posted: 12/09/20 12:14am Link  |  Quote  |  Print  |  Notify Moderator
Afraid to drive because of the Rona?
Some things are a mystery.
Almost as confusing as being afraid to camp because of the Rona....
May as well empty the tank because you won’t be driving it next year either based on current logic.
2017 Heartland Torque T29
BurbMan
Noblesville, IN
Posted: 12/09/20 06:51am Link  |  Quote  |  Print  |  Notify Moderator
How hot was the garage? Did you open the door at all during the summer? Hard to believe that you haven't driven the truck at all since Feb.
Hottest my garage got in August was 100*, but that was up in the rafters. The DEF tank on the truck sits down low, shielded from light and by the truck body, so probably never got hotter than ambient temps in the 80's.
Your DEF is still not a year old, it's probably fine. You should be driving the truck at least once a week to keep all the seals lubed and the fuel fresh. If you want to burn off some DEF, hook up the trailer and take a quick trip.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
 > Stale DEF
