RV.Net Open Roads Forum: Tech Issues: Diluted RV Antifreeze
 > Diluted RV Antifreeze
dougrainer
Carrolton, Texas
Posted: 12/09/20 07:53am Link  |  Quote  |  Print  |  Notify Moderator
cavie wrote:
You can afford an RV but you cant afford $2.50 per gal of anti-freeze? It only takes 2 gals to do most any RV.
Bingo, 20 years ago when full body paint on a Class A was a $10k factory option, people would pay for it. Then scream bloody murder when we charged $75 to wire their TOAD to the New Motorhome. Go Figure[emoticon] Doug
phil-t
Ogdensburg, NY
Posted: 12/09/20 08:57am Link  |  Quote  |  Print  |  Notify Moderator
So, after all this - is there something I can use in the grey/black tanks that will take some amount of water/dilution and not freeze? I'm thinking, leving northern NY in 0-20 deg. weather and heading south. Just beable to use the bathroom for washing, etc. till we get a day to the south.
BTW - I winterize by draining everything and adding pink stuff to the system.
2010 Winnebago Vista 32k on a 2009 Ford F53 22k chassis
pulpwood007
Hemphill, TX
Posted: 12/09/20 09:15am Link  |  Quote  |  Print  |  Notify Moderator
craig7h wrote:
WHY!
Reading the first sentence of my OP will tell you why.
pulpwood007
Hemphill, TX
Posted: 12/09/20 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Dutch_12078 wrote:
RV antifreeze is already mixed with usually de-ionized water and should be used straight from the jug. It will freeze at low enough temperatures, but the mixture does not expand to cause damage to fittings. Adding more water could upset that no expansion balance. I don't suggest risking it...
Thank you. That sounds like an accurate explanation. I never had any intention of experimenting with it in my trailer. Just an academic question for those interested in chemistry.
* This post was edited 12/09/20 09:29am by pulpwood007 *
Dusty R
Charlotte Michigan 48813
Posted: 12/09/20 09:50am Link  |  Quote  |  Print  |  Notify Moderator
I've figured that a small amount in the black & gray tanks will not hurt the tank if it freezes.
We have left Michigan in January & February, headed to Florida, used highway rest stops mostly the first day and night. Then after that not worried about the tanks.
Dusty
phil-t
Ogdensburg, NY
Posted: 12/09/20 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Dusty
Yup, my plan, was just looking to not needing to use rest stop facilities in the current state of things. We will manage.
KLYoung
Illinois
Posted: 12/09/20 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Why risk the chance of breaking your lines.
dougrainer
Carrolton, Texas
Posted: 12/09/20 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Dusty
Water will freeze. When it does it expands. Less than full in a fresh/grey/black tank can freeze but it has room to expand. BUT!!!!! It will freeze first closest to the dump valves and then you cannot open and dump. Fresh tank drain tubing/valves will freeze and crack. When the freeze water cannot expand it cracks piping and valves and especially elbows/T's of fresh pressure lines. Use a 1/2 gallon in each dump tank until you get to warm weather. Doug
DrewE
Vermont
Posted: 12/09/20 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Rock salt is one viable option for black and gray water tanks. It's probably not great for septic systems (in large quantities), but it will do fine to keep things from freezing down to reasonably low temperatures and will (with sufficient water) all dissolve and not cause clogging, will not attack plastic pipes, etc.
Terryallan
Foothills NC
Posted: 12/09/20 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
BB_TX wrote:
As you say, it is already cheap. Why risk it?
agree. at $2.50 a gallon how cheap can you get? But if saving $.050 per year is worth the risk. Go for it.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
