RV.Net Open Roads Forum: General RVing Issues: RV Entry Stairs - Replacement ???
 > RV Entry Stairs - Replacement ???
TenOC
On the road -- Full time
Posted: 12/08/20 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
I am think about replacing my 5er steps with either Morryde Step Above or Lippert Solid Step.
What are real life experiences with this type of steps??
Any negatives? It looks to me to be a coin toss between the two. So purchase the one with the best price.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
TUCQUALA
Kennewick, WA
Posted: 12/08/20 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
Early this fall, we replaced our steps with the Lippert unit. Liked the wider upper step for more stable feel. Install wasn't without some mods. Had to cut down the raised strip on the threshold plate for the step to fully drop down on top of the threshold. Also had to remove a bit from the screen door bottom and the "brush" sweep so doors close fully. Not really bad to do, don't know if the Moryde unit would have to have any mods, probably (??).
Usage is great, very solid feel, no bouncing or sagging under body weight. Setting the legs is somewhat of a hit and miss operation, each camp spot is different as to the trailer level. Not terrible, but need to get used to. One big thing is to have trailer level front to back before lowering steps, and NOT to do that with steps down. Can jam legs and bend step assy if done. As to clearance problems when stopping for short time, like rest area, or store, we have not had a problem putting the steps out with some vehicle next to trailer, but can happen!! A unit with 2 doors wouldn't have any problem, if main door blocked. Also, with steps up, not easy to put stuff in through door opening, minor problem!! Dirt and water, well, just put a little time into sweeping steps off and lay down a used towel or such before closing!!!
We did this due to the trailer step frame cracking from flexing of old steps under load. These will not do that, and we love them.
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
Cummins12V98
on the road
Posted: 12/09/20 03:53am Link  |  Quote  |  Print  |  Notify Moderator
They all have negatives. For rock solid quality replace with Elkhart Industries. I went with the aluminum tread model 4 step. At 200# I only deflect the bottom step 1/2”.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
wowens79
Georgia
Posted: 12/09/20 04:09am Link  |  Quote  |  Print  |  Notify Moderator
We put on a set of the Lippert steps. They feel really split, and I like the wide upper step.
The thing I don’t like, and I think it is the same on all of them is the pins on the adjustable legs. They need to come up with a better way to adjust.
2002 Chevy Silverado 1500HD 6.0l 241k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
ford truck guy
Pennsylvania
Posted: 12/09/20 06:02am Link  |  Quote  |  Print  |  Notify Moderator
We went from Stock steps, to aluminum/steel framed steps, to Torklift Glow Steps, and now have the Morryde Step above and love them.
MAny here have positives and negatives on BOTH,, This what most complain about
1- When traveling, the Lippert or Morryde are stowed inside the camper.. Some complain about this and think it is an issue... We simply keep a hand sweep and rag in the compartment next to the door. When packing up to leave, we simply raise them 1/2 way and wipe/sweep off then stow.
2- Some have said that IF they are too close to objects, they cannot lower the steps... we have been using these types for 5 years and have never ran into that as of yet.
The Lippert and Morryde are Very solid when using, with the Torklift Glow steps a very close second.
The Lipperst amnd Morryde both have strut assists now, and they are fantastic ! you can lower or raise with 2 fingers... and BOTH ( Torklift as well ) have adjustable feet for un even ground.
At the end of the day, it will be personal choice between all the pro's and con's
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
QCMan
Independent Republic of Horry
Posted: 12/09/20 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Down side to the strut assist is that it is only available with the strut on the left side looking in the door. A consideration if you have cabinets just to the left of the door.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Lightning55
Pleasanton, CA
Posted: 12/09/20 08:55am Link  |  Quote  |  Print  |  Notify Moderator
We installed the Step Above and my wife likes it a lot. Large upper step and solid, no bounce is a big improvement. Folding it up into the entry is a bit of a pain and it always puts dirt into the trailer when lifted up, but that's the only complaint we have. Only once did I ever have to move the trailer over in storage because I was too close to the next trailer to fold in down.
goducks10
There
Posted: 12/09/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
I replaced my noisy spongy aluminum steps with solid steps. We have a TT with 2 doors. After one season using them we love em.
HOWEVER when we had our 5er I was thinking of installing them on it. Glad I didn't.
The biggest drawback is that on a 5er it's the only way in. If you're anywhere thats tight it will be a challenge. If you pull off on uneven ground to just grab something from the RV or to 'P' then you have to adjust them before setting them down.
Not that big of a deal in the short term but after a whole season it gets old.
Also you can't deploy them until the RV is level, which means no one can get inside until then.
With a two door unit the above situations aren't an issue.
As far as the bringing dirt or water inside. After one season of camping in the dirt, gravel, rain, etc we never had an issue with that. Just broom them off before putting them back inside.
way2roll
Wilmington NC
Posted: 12/09/20 10:12am Link  |  Quote  |  Print  |  Notify Moderator
After having MH's for years with the Kwikee electric steps, we love the FW with the MorRyde steps. The pros definitely outweigh the cons and the cons aren't really cons but rather a different way to to deal with them.
The good; super stable, easy to deploy and stow, no electric parts to fail, adjustable.
Things to consider; They do pull dirt into the RV unless you brush them off first, you need enough distance between you and something next to you in order to deploy them. In 6 mos of ownership this has really only been an issue at a storage lot and I have some control over that.
In short, we love them and wouldn't trade them for the old style for anything.
ReneeG
Meridian, Idaho
Posted: 12/09/20 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Keeping our standard stock steps.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
