RV.Net Open Roads Forum: Tech Issues: One 6V battery discharging really fast
 > One 6V battery discharging really fast
RichieW13
California
Posted: 12/10/20 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Almost 3 years ago I swapped out my 12V battery for two 6V (Trojan T-105) batteries.
Last weekend, I noticed that my trailer was losing power really fast after charging up. I used a volt meter and discovered that one battery was reading ~4 volts and the other was reading ~6 volts.
The water level looks to be fine on both.
Is it possible that one battery is just bad? Is there some other issue I should look for? Should I just replace the bad battery, or do I need to replace both to keep them approximately the same age?
madjack60
littleton
Posted: 12/10/20 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
Almost sounds like a cell in the battery is dying
wopachop
Who run bartertown
Posted: 12/10/20 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Know anyone who could bring over a charger capable of doing an 8v equalization charge?
Or if you have a 12v Battery Tender you can possibly use that on the single 6v.
time2roll
Posted: 12/10/20 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
I believe you have happened upon the very rare situation where your GC2 has a shorted cell.
Check your warranty but I think you need a replacement.
675w Solar pictures back up
RichieW13
California
Posted: 12/10/20 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Are you saying that the method of charging the battery can impact the length that the charge will last?
wopachop
Who run bartertown
Posted: 12/10/20 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
As mentioned above you might have lost a cell.
You can try what's called an "equalization charge" and see if the bad battery can still be used.
Wonder if the possible bad cell actually looks different if you shine a flashlight at night down the water holes.
RJsfishin
Winston Or.
Posted: 12/10/20 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
OP
don't let them confuse you. You need a new battery. There aint no kind of equilizing (hi voltage) charging going to fix that battery w/ a stone dead cell.
Its just too bad you went w/ the hi $ Trojans, as you should replace w/ same.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Bishop area, California
Posted: 12/10/20 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Certainly! Correct voltage for bulk, absorption, float and equalization are important. Trojan has the numbers on their site. .
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
2oldman
NM
Posted: 12/10/20 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
It's possible a bad connection can limit charging current to the one battery. 3 years is a year sooner than I went through Trojans, but maybe your usage is heavy. Replace both.
* This post was edited 12/10/20 03:54pm by 2oldman *
Posted: 12/10/20 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
X2, 2oldman. Replace both batteries.
