RV.Net Open Roads Forum: Tech Issues: Small PSW Inverter
 > Small PSW Inverter
Williams AZ area
Posted: 12/10/20 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
I need a new light duty PSW inverter. Any comments regarding Bestek?
BESTEK 300Watt Pure Sine Wave Power Inverter Car Adapter DC 12V to AC 110V with 4.2A Dual Smart USB Ports
https://www.amazon.com/BESTEK-300Watt-Power-Inverter-Adapter/dp/B07KQ4Q2L5/ref=sr_1_7?crid=SKSTKD2K738G&dchild=1&keywords=pure+sine+wave+power+inverter&qid=1607650206&sprefix=Pure+sine%2Caps%2C689&sr=8-7
BFL13
Victoria, BC
Posted: 12/11/20 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/BESTEK-300Watt-Po........206&sprefix=Pure+sine%2Caps%2C689&sr=8-7
No way will you do 300w with the 12v plug-in. The socket will be more like a 96w limit. If you can modify it to use clamps on the wires to go right on a battery, that would be a very good deal at that price.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
theoldwizard1
SE MI
Posted: 12/11/20 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Most vehicle 12V plugs have 20A or 30A fuses. 20A @ 12V is 240W.
Not sure if this unit can handle 300W on an "extended" basis. I don't know if I would be comfortable enough to leave a 250+W load plugged in to a cigarette lighter UNATTENDED !
Williams AZ area
Posted: 12/11/20 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
BFL, it’s for my TV. Uses 45 watts plus inverter loss, so it will work. TY for responding. You too Wizard.
Veebyes
Posted: 12/11/20 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
I'd have to run the numbers but using a PSW sure sounds preferable to a MSW.
300W should run a phone, the dashcam, the GPS & a laptop.
2007 Alpenlite 34RLR
Boon Docker
Posted: 12/11/20 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I do believe the max for 12v vehicle outlets is a 15 amp fuse.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 12/11/20 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I am satisfied with my Samlex 300 PSW. Anker makes excellent USB chargers for cigarette light user.
True to form Orientals make true garbage power connectors. A Blue Seas marine plug and socket fed by a dedicated TEN AWG cable and 30-amp fuse I'd the ideal power feeder.
BFL13
Victoria, BC
Posted: 12/11/20 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
I was going by the socket in an RV Winegard TV panel, which is on thin wire and rated for 96w/8 amps and a 10 amp fuse (at least that was how it was in the 2003 5er we had.)
Don't know about actual cigarette lighter sockets in a dashboard. They are on the engine battery if that matters.
markchengr
Seattle
Posted: 12/12/20 10:40am Link  |  Quote  |  Print  |  Notify Moderator
There is another version of the same inverter near the bottom of that Amazon page. It allows for threaded stud connections. Suggest you get this one and use no. 8 wire to connect direct to the battery. This will give you full output current ability.
time2roll
Posted: 12/12/20 11:30am Link  |  Quote  |  Print  |  Notify Moderator
I mounted my 300w inverter behind the power distribution panel. Use the main 12v battery feed for power and a small transfer switch to connect to each branch circuit of outlets.
No experience with BESTEK. Probably fine.
675w Solar pictures back up
