RV.Net Open Roads Forum: Tech Issues: Small PSW Inverter
 > Small PSW Inverter
2oldman
NM
Posted: 12/12/20 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
The only CON I could find was that its no-load draw is pretty high.
RJsfishin
Winston Or.
Posted: 12/12/20 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
If its cheap, that's what it is. I have tried 3 inexpensive psw inverters, and all 3 were junk, had herringbone across the tv screen, and or a hum in the audio. and high draw at idle. Went back to msw and never looked back and never a problem. I don't know what all the hype is about psw.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
2oldman
NM
Posted: 12/13/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Did you buy a cheap msw?
RJsfishin
Winston Or.
Posted: 12/13/20 10:22am Link  |  Quote  |  Print  |  Notify Moderator
I put the one back in I'd been using for at least 5 yrs, got it from a trucker, don't know the original price.
S Davis
Western WA
Posted: 12/13/20 11:10am Link  |  Quote  |  Print  |  Notify Moderator
MEXICOWANDERER wrote:
I am satisfied with my Samlex 300 PSW. Anker makes excellent USB chargers for cigarette light user.
True to form Orientals make true garbage power connectors. A Blue Seas marine plug and socket fed by a dedicated TEN AWG cable and 30-amp fuse I'd the ideal power feeder.
Just make sure you get pin terminals if you go bigger than 8 awg, I found this out yesterday. I had to install the inverter about 6’ from my cab connections under the center console and they recommend 6 awg, guess what 6 awg will not fit.
Inverter shelf
* This post was edited 12/13/20 11:30am by S Davis *
time2roll
Posted: 12/13/20 11:13am Link  |  Quote  |  Print  |  Notify Moderator
My experience has been the exact opposite.
675w Solar pictures back up
BFL13
Victoria, BC
Posted: 12/13/20 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Just use 6" of #8 as pigtails and then go #6 from there. Various ways to joint the #8 and #6 ends.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
S Davis
Western WA
Posted: 12/13/20 11:37am Link  |  Quote  |  Print  |  Notify Moderator
CAUTION!
DO NOT insert the stranded bare end of the cable directly into the tubular hole as the set screw will not pinch all the strands, resulting in a partial / loose contact and consequent overheating. To ensure firm contact, use suitable pin type terminal similiar to the termi- nal lugs provided with 2 types of detachable DC input cable sets provided with the unit (See Section 8.4.7).
I thought about doing that but the instructions say not to put stranded wire into the terminals, and after looking more closely I can see why, the set screws are really small and will not clamp all the wire so half the wire is loose.
* This post was edited 12/13/20 11:43am by S Davis *
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 12/13/20 11:45am Link  |  Quote  |  Print  |  Notify Moderator
From TIRES to T-BONES cheap does not imply a smart purchase by any measure. I have a saying that goes like this...
I've suffered a two-dollar meal that was a ripoff, and was thoroughly satisfied with a fifty dollar extravaganza I considered to be a bargain.
I did not get a nickel's worth of discount on my Trace 4024 MSW inverter that arrived when Ronald Reagan was in office. But it still works (some repairs)
I just bought a computer USB keyboard for twenty dollars. It weighs about 2 pounds but its reputation is that aside from drowning it is invincible.
I checked out the SAMLEX waveform on my Tektronix scope. Near 320 watts its sinusoidal waveform is flawless.
When I check power bricks, and they run 10-20 degrees warmer under load on my Trace inverter that's the end of the road for their quasi sine wave operation.
When I do not have enough money to buy other than junk grade stuff, the money goes into a piggy bank until I accumulate enough to buy better than chew-and-spit grade.
It just does not pay.
Dickies brand pants and shirts are not cheap and seldom found discounted. But the pants and shirts I purchased EIGHTEEN YEARS AGO are absolutely useable around the house. They have no rips or tears, no thin spots, no missing buttons, and have outlasted what (?) five or seven similar items at a third the price?
Lifetime guarantee tools are stupid if you end up paying four times their price in gasoline to exchange them after they break.
If you save fifty dollars on an inverter and it imitates Krakatoa, how much are you saving? You lost use of it. Get out your calculator because until you replace it you are going to accumulate nothing but lost money, lost time and lost usage of an inverter.
I would like to purchase lots of things right now. But I am not going to play stupid and buy junk. I do not have enough money to waste it.
MrWizard
Traveling
Posted: 12/13/20 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
Inverter or converter
Round hole set screw fastening stranded wire !
I use copper crimps normally used for joining several #12 or #10 solid wires
I slip it over the end of the stranded wire, crimp it, now I have a pin connector, put that in the terminal and tighten the set screw
If the crimped wire is too large for the terminal, but the wire is a close fit, I can apply solder to the wire, and make the end of the wire the pin for the terminal, crimping is quicker than soldering, and I have not had any problems with this method , a good tight crimp is a solid physical connection, and allows the set screw to get a good tight connection, no loose spreading strands
