RV.Net Open Roads Forum: Travel Trailers: Shutoff valves for appliances?
 > Shutoff valves for appliances?
trail-explorer
NM
Posted: 12/16/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Old-Biscuit wrote:
3/8" inverted flare cap...done
Or
Remove fridge gas line back at the 'T' and install a pipe plug...done
No 'brazing' required as RV LP System is screwed together from TANK to main line to 'Ts' to each appliance...screwed together
All the above.
I installed a cap. Done.
I've never seen propane line brazed. Copper plumbing, yes. gas line, NO.
Like Old Biscuit says, RV Propane systems are generally all screwed together.
Bob
deltabravo
Spokane, WA
Posted: 12/16/20 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Inverter flare cap or plug.
I'm in the middle of installing an inverter, which required removing my oven/stove unit. I needed propane heat in the rig, so installed a cap shown at this point in the video
I later removed the cap, reconnected the copper propane line and then installed an inverted flare plug on the piece of flared copper tubing that I reconnected where I had the cap.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
