RV.Net Open Roads Forum: Truck Campers: Trailer hitch extension arms for rear tie-downs
 > Trailer hitch extension arms for rear tie-downs
north*mom
North America
Posted: 12/11/20 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, I'll be replacing the hitch on my 2005 F350, I'm planning to get a Class V hitch for pulling my horse trailer. Looking for advice on what to look for and where to find a hitch that also includes the side arms I'll need to use for attaching the chain tie-downs for the rear of my camper - I'm not sure what those pieces are called. Can I buy a hitch that includes those pieces or are they separate items? My truck is a long bed.
K Mac
Lower Hudson Valley N.Y.
Posted: 12/11/20 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Google Torklift Super Hitch, Magnum Hitch.
Near DVNP, California
Posted: 12/11/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
You plan to tow 16000 to 17000 pounds? That puts your hitch weight at about 2300 pounds. Should be ok.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
NewportNic
MI
Posted: 12/11/20 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Here is what my Superhitch looks like...
Posted: 12/11/20 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Now that’s a truck rear end!
jimh425
Western MT
Posted: 12/11/20 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
You hitch solution has a lot to do with your camper length. For the very long campers, it seems like Torklift has no equal. Longer extensions typically come with everything you need.
I have a 9 1/2 camper so I barely need an extension for my 2 1/2 hitch, and no extra chains are required in my case.
Buzzcut1
Norcal
Posted: 12/11/20 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
There is no way on earth that I would trust the life of my horses on any hitch and hitch extension system other than Torklift. I have used this system safely for over ten years traveling all over the country showing horses Super hitch, super truss and a weight distributing hitch at the ball.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Kayteg1
California > Nevada
Posted: 12/12/20 08:18am Link  |  Quote  |  Print  |  Notify Moderator
I wonder if you can buy new 3" hitch from Ford that would fit your older model?
I love the 3", where 4 ft stinger cost me $40 and per my rough calculation is stronger than Torklift stingers.
Used it also to convert my truck to portable crane with my engine hoist.
I posted a picture before -showing that Ford's heavy hitches have brackets reaching rear springs mounts, not just attached to the rear of the frame.
ajriding
st clair
Posted: 12/12/20 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Sadly, you need the Superhitch as pictured in that GIANT large wide photo above. There really is no alternative.
The Superhitch uses two square tubes instead of one as in a typical receiver. This is critical for towing your heavy trailer.
I used a long extension on my 2 inch class V but was towing a lighter trailer. It worked but I was never fully confident in it. Wen u extend the hitch like that there is a lot more torque pushing on the extension.
The tie-downs for your camper are a secondary concern. Lots of ways to make that happen. Get the right hitch, the Superhitch, then figure out the rest. You can bolt on the Torklifts, or weld them, or maybe the Superhitch has a solution for you...
Kayteg1
California > Nevada
Posted: 12/12/20 11:47am Link  |  Quote  |  Print  |  Notify Moderator
[image]Click For Full-Size Image.
Comparing Torklift mount and Ford's mount - Ford is using double side plates for heavy hitch, Torklift single plate.
