RV.Net Open Roads Forum: Class A Motorhomes: LED Interior Bulbs
 > LED Interior Bulbs
wopachop
Who run bartertown
Posted: 12/11/20 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
These are cheap PWM dimmers ive been using for about 5 years. Comes with a remote control which is awesome. The light in the picture is in my trailer!! Was a quick test setup. You can see it hanging there by the wires. Being lazy i just left it and laugh how it hasnt failed yet.
wopachop
Who run bartertown
Posted: 12/11/20 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
DrewE
Vermont
Posted: 12/11/20 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
wopachop wrote:
QCMan wrote:
Not all led's can be dimmed. Buy ones that can be dimmed if that is your plan.
Every LED can be dimmed with a cheap voltage regulator. More efficient way is dimming through pwm.
LED lamps that use ballast resistors to control the current will be dimmable with a voltage regulator (or PWM dimmer). Those that use some sort of an active driver circuit very often won't dim with a voltage regulator, and may not work with a PWM dimmer either; the driver circuit will adjust for the changing input power, exactly as it's designed to do.
Ava
Vancouver Island. BC Canada
Posted: 12/12/20 12:28am Link  |  Quote  |  Print  |  Notify Moderator
I use the brighter led bulbs, 3000k on the ceiling and a warmer 2700k led bulbs on the wall sconces. That way I have bright lights when needed and softer lights the rest of the time.
Wherever I happen to park
Posted: 12/12/20 03:53am Link  |  Quote  |  Print  |  Notify Moderator
Well if you want to buy good (But Expensive) LED's ECO-LED at most RV dealers are great, but 20 bucks a pop..
IF you buy from any one line source (closer to 2 bucks or less a pop) buy a minimum amount take notes, if you like 'em buy more if you don't cross out that vendor or lamp.
SuperBrightLeds Is I think the name of one on line vendor who gets decent reviews... I've not purchased from them.
Home is where I park it.
MrWizard
Traveling
Posted: 12/12/20 04:13am Link  |  Quote  |  Print  |  Notify Moderator
I like the daylight lighting led fixtures
The bluish cool lighting, well IMO kinda sucks
The warm white, meant to simulate incandescent bulbs, is too yellow, not white enough, not bright enough, warm white use 1/2 brightness you normally like, if looking for Mood Lighting
Radiate The Happy
1997 F53 Bounder 36s
Executive
Posted: 12/12/20 09:11am Link  |  Quote  |  Print  |  Notify Moderator
You'll replace the CHEAP ones within a year. You'll get what you pay for. IMHO, eBay and Amazon are not the places to buy the China made products. Superbrightleds is highly recommended. You don't have to buy the most expensive, but stay away from the cheapo ****....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Sjm9911
New Jersey
Posted: 12/12/20 10:18am Link  |  Quote  |  Print  |  Notify Moderator
My chepo amazon ones are going strong 4 years later? Yes, some are better then others, check the reviews before buying. I also have a mix of the yellow light and the daylight ones. Daylight over the kitchen area, all else are the yellow ones. Makes a difference when cooking and looking for stuff. I got the ones where all the leds face the same direction ( like someone above posted), gives more light. The other ones shine the light in all directions. So they shoot light upwards into the fixture.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
alvie h
al.
Posted: 12/12/20 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced most of mine from etraier.com. I replaced complete light for about 16 dollars each. Soft light completely happy.
1320Fastback
Vista, Ca
Posted: 12/12/20 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I got some from Amazon in packs of 20. I needed 27 so have some extras for some burn out. So far none have.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
