RV.Net Open Roads Forum: Class A Motorhomes: Water proofing slide toppers.
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > Water proofing slide toppers.
John Wayne
Long Beach, Ca
Posted: 12/12/20 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
Just set up a tad off level front or rear slide out side low ( water will run to out side of slide)
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
dougrainer
Carrolton, Texas
Posted: 12/12/20 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
What do you do when you have slide rooms on each side[emoticon] The water will still START either at the front or rear depending on off level. Or course, this WILL minimize water leak thru seal. Doug
doxiemom11
Victoria TX
Posted: 12/12/20 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
If this is an older topper, is it really canvas or not? If it is - clean it and waterproof it with stuff that is for tents.
dougrainer
Carrolton, Texas
Posted: 12/13/20 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Monaco, If the Poster has a older Monaco, usually used Carefree which is a cloth/canvas material, for the slide toppers. Doug
Dale.Traveling
Newport News, VA
Posted: 12/14/20 08:35am Link  |  Quote  |  Print  |  Notify Moderator
First fix the topper. The fabric should not droop and there should be some tension from the topper rollers holding the fabric in tension. If not then either the tension springs need to be tightened or one of the springs has failed. If both have failed the topper would not roll up at all.
Next the material should already be water resistant just like your awning. If the material is old and degraded consider having new material installed at the same time as the tension springs are checked.
And finally check the seals between the slide and the coach wall. The seals should be in firm contact with the slide surfaces. If not that could be a place water can get in along with hot/cold air drafts, insects and blowing dirt and will need to be looked at to see if anything can be done short of replacement ($$$) to improve the seal.
2006 Hurricane 31D built on a 2006 Ford F53
chuckftboy
Fleming Island, Florida
Posted: 12/14/20 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Star Brite makes a spray water proofing for canvas and cloth. Its used on tents and can be found at Sporting Goods Stores or on line.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
4x4van
California
Posted: 12/16/20 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
The slide toppers' purpose is not to keep water out of the coach; it is to keep debris/sun off of the slide roof, and yes, it can reduce (but not eliminate) water on top of the slide. But that water should not enter the RV regardless; many RV's don't even have toppers on the slides. The main problem the OP has is that the top seal on the slide is faulty.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
dougrainer
Carrolton, Texas
Posted: 12/17/20 08:47am Link  |  Quote  |  Print  |  Notify Moderator
While this is true, older Monaco motorhomes HAVE to have a slide topper to stop water intrusion. This is why the Monaco's came with slide toppers. They had inadequate J drip rail systems that prevent a large amount of water that runs off the roof radius's right onto the upper slide seal. I base this on my almost 26 years of working on Monaco Motorhomes and having to deal with slide room leaks that did NOT go away after replacing the complete slide seal, when the Customer did not want to repair/replace the defective slide cover or the cover was removed after is came apart from damage or age. After the seal was replaced and tested the room still leaked. With an operational Slide cover in place the leak went away. Doug
4x4van
California
Posted: 12/23/20 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Interesting. Sad, but interesting.
jackieo1950$
Illinois
Posted: 01/01/21 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
I had the same issues & found a safe to my acrylic toppers called
losso fabric protector..boy what a difference once I applied the 2 coats...but you need to make sure your topper is tight so you might have to do a fresh wind on your roller spring...www.losos.com I bought Dometic Slide Topper Cradle/Support Kits for both supersize slides awning...didn't know they even existed til I saw one on a fellow campers coach..Dometic doesn't even show them on their site..you have to ask them or just Google it. They're designed to keep the slide roller 14' or longer from flexing inward when wind or water are present. Problem solved after installing them..not cheap but neither is replacing a roller & or a topper. There are 3 different sizes to fit the right application. If you look hard you can find them for a lot less than what Dometic sells them for IE:
Amazon...RVeParts.com are just 2....Hope this info helps!
