RV.Net Open Roads Forum: Toad or No Toad ?- Grand Canyon road trip in a 23' class A
Open Roads Forum  >  Class A Motorhomes  >  Travels & Favorite Places
 > Toad or No Toad ?- Grand Canyon road trip in a 23' class A
ArchHoagland
Clovis, CA, USA
Posted: 12/12/20 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
I'm curious what your travel dates are.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
hertfordnc
Hertford, NC
Posted: 12/13/20 07:07am Link  |  Quote  |  Print  |  Notify Moderator
Probably June 24 to Jul 18
Dave & Ellen Silva
Hertford, North Carolina
2002 Excursion
2007 Shamrock Hybrid
1972 Revcon
ArchHoagland
Clovis, CA, USA
Posted: 12/13/20 10:33am Link  |  Quote  |  Print  |  Notify Moderator
June 24 to July 18...It will be over a 100 degrees out here so make sure your air conditioner works and your engine radiator is clean.
One advantage of a toad is if your RV dies out in the middle of the desert you can use the car to get to a town.
Have you ever traveled out west anywhere?
hertfordnc
Hertford, NC
Posted: 12/13/20 11:29am Link  |  Quote  |  Print  |  Notify Moderator
I figure if the coach air and the generator are both working i will have redundancy for that sort of breakdown.
I've lived in the East Bay and the PNW, traveled up and down the west coast a few times but I am much older and wiser now so i'm approaching this as a total noob.
wapiticountry
Mountain West
Posted: 12/13/20 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
You have another thread where you seem to be concerned about the ability of the GMC to climb and descend the mountain grades. If that is the case, definitely take the towed, and disconnect it and have your wife drive it on those big grades. You can use it to reduce the weight in the rig (your wife, the kids, some of the gear in the towed on the grades) and it will be a life saver should the old girl (the RV, not the wife) have a problem. As a general observation, I have always found a towed to be a near necessity. It allows you to tour, run errands and go places the rig can't go all without the time and effort of breaking camp.
hertfordnc
Hertford, NC
Posted: 12/13/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
That is a separate question just to add to the decision tree- the plans are all fluid at this point so knowing which passes are the most challenging may drive decisions about which sites and which relatives we see and in which order.
winnietrey
seattle
Posted: 12/13/20 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
did 15 years in a 24ft C with no toad.
Couple of thoughts
At 24ft much easier to find a campsite, than with the MH plus a toad
Easier to stop in some small town, or small roadside attraction
As for the big parks ( and have been to 90% of them in the west) the parking is always going to be a problem, no matter if you are in a car or not. so best advise, get up early, hit the park as soon as it opens, you will have no problem parking a 24 ft
hertfordnc
Hertford, NC
Posted: 12/13/20 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Couple of thoughts
Yeah i think the decision is made. I just took it for a drive down the tiniest streets in my town- 23' 5", front wheel drive, it's really just a big car. With the rear overhang i can sneak it into a regular parking space.
howdy35
Athens, Texas
Posted: 12/14/20 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I personally would take a towed, but my thought is, "What would you pull with an older motorhome that would be light enough to pull in the western mountains?" You would certainly have to be selective to get something light enough to pull and be able to stop it. Also the suggestion about unhooking and driving the toad up long passes is a good idea with that unit. .
Best of luck on the choice you make and I hope you will have a great trip. It would be interesting if you posted what you did and how it went.
Happy travels
Arnold
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
ItsyRV
Desert SW
Posted: 12/14/20 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
My RV is just under 22 feet. Overall I have not had the need to drag a toad with me. But, let me first say that my travel plans are designed around not having a toad. So it's not that one isn't necessary based solely on the RV size, it's that one is not necessary based on how I plan my activities based on not having a toad with me due to the RV size.
One important item is that length isn't the only consideration; remember the height and width could be issues at times. I may not be able to fit reasonably in a parking lot close to an attraction, or park along a street with low trees. There may be an attraction where travel could be hindered by low clearance or too narrow a winding path. So, planning to avoid problems is just part of things when going without a toad.
I think the biggest issue are the hookups when staying for days at an RV park and using the RV for day trips. Many get tired of the hook ups each time they leave and come back. This can easily be solved with repetition and easy connectors that lessen the hassle factor. Of course if you're sightseeing during travels between spots, it's no big deal.
Another handy way is to use the RV as transport. I may travel from the RV park to a sightseeing destination but park in a convenient (and safe) spot where I can bike to the finial attraction. Nothing says you have to have the RV right outside the door. I have gone places, parked a couple miles away, used the bike (electric) and been at the attraction while others in their cars are stuck in traffic, circling parking lots looking for spot and end up still parking way back with a decent walk.
This doesn't mean there hasn't been times where a toad would have come in handy. I have had to rent a car once or twice to be able to go somewhere That an RV or a bike (electric or peddle) isn't practical. But for those few occasions, I have to decide to get alternative transportation or forgo the attraction; it's just planning. I found that there usually isn't that may places I can't get to due to my RV size. And, if I can't get right to it, I can at least get close enough that a short bike ride is worth not having to bring a toad with me all the time.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
