RV.Net Open Roads Forum: Tow Vehicles: 6.6 Chevy gas engine
Search only in Tow Vehicles
 > 6.6 Chevy gas engine
gmckenzie
BC
Posted: 12/14/20 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
LITEPHIL wrote:
Very interested in the 6.6 gas 3/4 ton. Yes we are all spoiled these days, I remember the family of eight going up to the Sierras in my 54 Carryall/Suburban (that I still have) in the 60s, towing an 18 ft Aljo trailer and a Honda 90 on the front and rack on the roof. Dad was dancing between Granny and second all the way up and had to pull over a couple of times to cool her down and we ended up putting the motorcycle inside the trailer but what a journey that was.
My 2019 RST Silverado tows great with alot of power with the 5.3 and that 8 speed but once you tow with a 3/4 ton,it's hard to go back to a half ton.
I would like a ten speed but the couple people that I've talked to say its a non issue pretty much.
I'm skipping the 3/4 and going 1 ton. But that's more because of stupid tax rules in BC than what I need. Looking at Ford/GM, the 3500/350 is between $800 and $1,000 more than a comparable 2500/250, and gives around 800 lbs more payload. But in BC the 3/4 ton attracts a 3% luxury tax that is not applied to a 1 ton, so the 1 ton ends up cheaper out the door.
I like my Sierra, but with an 8,200 lbs trailer I am right at the limit according to the scale I went over last summer. But I do not want a diesel.
2015 GMC Sierra 4x4 CC SB Max Trailer
2010 Cougar 30RKS
Sjm9911
New Jersey
Posted: 12/14/20 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
I will add, im tall and it has a lot more room for me in the cab. So everything is bigger. Some might not have these problems, but its nice to atually have head room and to be able to see out the front windsheild. Much better then the gmc 1500 I had. So far for me the 6 speed has not been an issue. But again my TT is light. Towed it on a few long trips this year. All mountains, I had no problems , gas millage was a bit better towing then with the 2012 GMC seirra 5.3 (?) with max tow package. I had plenty of power to pass in the deleware water gap area. With the 1500 I had to slow down to the truck lanes they put in because they cant pull the mountian. The 2500 , not only pulled it but could speed up to pass. And to be honest, thats what i wanted, more control. The 1500 could pull what i had, but the 2500 makes it less of a chore. And i also didnt want a diesel. I still remember going off to a state campgeound up by niagra falls, and my neighbor had to travel like 30 minutes to get to a station that diesel. Hunt and find is not for me. Im sure this is not normal, but it soured me on the diesel thing.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Posted: 12/14/20 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
^ But the cab is the same size as a new GM 1500, so?
And the hard to find diesel one time reason is classic!
kellem
Shenandoah valley,VA
Posted: 12/15/20 05:02am Link  |  Quote  |  Print  |  Notify Moderator
We live far from the metropolitonians where truck buyers were taught to be very biased.
If dad had a Chevy then by gosh you had better own Chevy's your entire life or it was considered BLASPHEMY.
As I got older, I strayed from this mentality and took my licks.
So as an unbiased truck owner, I've come to realize that whoever is offering the best package when I'm in need of a new truck then that's the truck that I end up purchasing.
Two very close friends own 2020 6.6 Silverado's, very sharp looking trucks and both very satisfied.....lots of HP per displacement.
My 2004 Dodge Ram 2500 needed to be retired so the process began to find a new truck to pull our 30ft trailer. Diesel was not a consideration as truck would sit for long periods.
At the end of year long process and research I found Ford to be one step ahead with the 7.3 10spd so bought 2021 F250 and been quite impressed.
I'm sure I would not have been disappointed with the Chevy 6.6 or Ram 6.4 , super nice trucks.
Dadoffourgirls
China, MI USA
Posted: 12/15/20 05:21am Link  |  Quote  |  Print  |  Notify Moderator
Many are discrediting the 6 spd. I am sure that my fuel economy running empty may have been better with a 10 sp. However, here in Michigan, gooseneck towing 16k lbs I never thought I needed another "in between" gear. I am sure somebody has a chart of rpms at speed with 6 gears and with 10 gears. Maybe there would be one speed that I could have dropped rpms. I did most of my 16k lb towing at 55 mph, and did my TT (9400 lbs) at 65.
I also took my TT to Kansas and back in July, but used a Duramax with the 10sp. That allowed me to tow with comfort.
I know that I am biased toward the GM truck.
Dad of Four Girls
Wife
Employee of GM, all opinions are my own!
2017 Express Ext 3500 (Code named "BIGGER ED" by daughters)
2011 Jayco Jayflight G2 32BHDS
Posted: 12/15/20 10:14am Link  |  Quote  |  Print  |  Notify Moderator
^Its not necessarily about dropping rpms, it’s about the right rpms at the right time.
10 speeds behind high revving gassers? I would agree, not necessary and 6 gears does 90% + of what 10 will do.
Comparing 5 vs 8 in our last 2 SRTs, honestly also not needed. Better but old was good.
And also not towing.
Imo 8 is the sweet spot and 10 is starting to get redundant on a gasser.
Diesel, about the same. 6 is ok, if they’re the right ratios, 8 is great, 10 has its place in super heavy towing, otherwise getting towards redundancy.
With most everyone at 8-10 gears. Ridiculously good power output across most all gas and diesel trucks, what is the next “big thing?” I’m running out of ideas to improve these trucks that don’t involve modifying the laws of physics!
kellem
Posted: 12/15/20 11:59am Link  |  Quote  |  Print  |  Notify Moderator
With 10spd transmissions and more torque offered lower in the rpm range with these big displacement NA engines, fuel economy doesn't suffer.....that was the goal.
gmckenzie
BC
Posted: 12/15/20 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
IMHO The next big thing will be working electric vehicles. Without range anxiety and with fast charging. But this will be far enough away that the current trucks are still good to buy.
Sjm9911
New Jersey
Posted: 12/15/20 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
I was comparing the size to the old one i had. Much more room in this one. Its also about the windshild, i didn't look at the 1500s this year though. On my 2012 sieara 1500, my eye veiw was at the top of the windsheild and my head was a quarter inch off the roof. The 2002 sierra i had had a much larger windshield veiw when seated. Tbh , i probably could have gotten a sun roof on the 2020 and still have enough room to fit.
Yea, something always sticks in my mind. Lol. Plus i dont need it. Don't plan on going much bigger for a TT. I will let you all know how it handles in the snow with factory tires in a few days. I have to go into work during the storm over here and im sure if we get a foot or two of snow it will not get cleared. Not sure if i will add weight to the bed yet. I might just see how it handles by itself. It seems heavy enough to get traction without adding weight. But im still undecided as getting stuck is not on my to do list.
Dadoffourgirls
China, MI USA
Posted: 12/16/20 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Sjm9911 wrote:
... I will let you all know how it handles in the snow with factory tires in a few days. I have to go into work during the storm over here and im sure if we get a foot or two of snow it will not get cleared. Not sure if i will add weight to the bed yet. I might just see how it handles by itself. It seems heavy enough to get traction without adding weight. But im still undecided as getting stuck is not on my to do list.
I would add a couple hundred pounds. I think that makes the difference for snow traction. I ran between 200 lbs and 400 lbs last winter based on when I needed to feed the Goats or put salt in the water softner.
