RV.Net Open Roads Forum: Travel Trailers: water pressure regulators
 > water pressure regulators
MarkTwain
Northern, Ca. , USA
Posted: 12/12/20 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Looking to replace my water pressure regulator. Which one is the best and why?
bgum
South Louisiana
Posted: 12/12/20 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Watts
Quality
bob213
Fresno, CA
Posted: 12/12/20 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Good ones are not cheap. Don't remember paying this much for mine but price of brass has increased. Any of the Watt's 263A models will give you good service and are rebuildable.
I have this one: 263A w/ oil filled gauge
Sjm9911
New Jersey
Posted: 12/12/20 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Ill take 2 plastic ones instead. Wholly cow thats a lot.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Sjm9911
New Jersey
Posted: 12/12/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/Camco-Pressure-Regulator-High-Pressure-40055/dp/B003BZD08U
I have one of these, works fine for me. If its not enough pressure, fill the tank and use the pump. I dont need one thats adjustable. You may require something diffent. I also have a plastic one. That gets used when i loose the other one!
QCMan
Independent Republic of Horry
Posted: 12/12/20 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Do you want a true pressure regulator or just a pressure/flow reducer? You will pay in money for the first and you will pay for the latter many times as they typically do not last long before causing problems.
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Lynnmor
Red Lion
Posted: 12/12/20 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
There is no such thing as a flow reducer, only pressure regulators. The barrel shaped plastic and brass regulators can be restrictive and nearly all of that type are junk. You don't need to pay the premium price of a Watts, any of that type may be fine.
garyemunson
Reno, Nevada
Posted: 12/12/20 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Amazon is your friend. Get an inexpensive one with a gauge. The small inline ones restrict the flow too much for my liking.
ktmrfs
Portland, Oregon
Posted: 12/12/20 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
watts adjustable regulator.
2011 Keystone Outback 295RE
edatlanta
Maplesville, AL Home Base
Posted: 12/13/20 04:35am Link  |  Quote  |  Print  |  Notify Moderator
263A for me. Full time 10+ years.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
