RV.Net Open Roads Forum: Travel Trailers: Light Problem
 > Light Problem
hpdrver
Mansfield, Texas
Posted: 12/12/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have been trying to troubleshoot an exterior light problem on my son-in-law 2011 Dutchman trailer. The two exterior lights do not work. I checked the switch and it was okay. I changed the fuse for these lights and still not fixed. However, there is a strange issue.
In the distribution box of fuses, there is a little red light for each fuse. When I pull out a fuse, the red light comes on for all the fuses in the box except the exterior light fuse. When I pull this fuse, the red light does not light up like it does for the other fuses.
Any thoughts on what is wrong is appreciated. Thanks
Texas Two Step
2021 Coach House 272XLFR
2020 JL Jeep Wrangler
MFL
Midwest
Posted: 12/12/20 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe a loose wire connection to that fuse, somewhere in the distribution box. Never hurts to tighten all connections every so many years.
Jerry
BarabooBob
Baraboo, WI
Posted: 12/12/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Try pulling the fuse for the outside lights. Next connect a jumper wire from the supply end of one of the other fuses to the feed side of the outside light fuse. Check the function of the outside lights. If the lights work, your problem is within your power system. You can make the jumper by using male spade connectors and a short wire.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
BarabooBob
Baraboo, WI
double post
12th Man Fan
Flower Mound , Texas
Posted: 12/12/20 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Not trying to be a wise guy but did you check the bulbs. When I got my RV both bulbs were burned out.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
wing_zealot
East of the Mississippi
Posted: 12/12/20 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like you have no power coming into the fuse.
hpdrver
Mansfield, Texas
Posted: 12/12/20 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
First thing I did was replace the bulbs. No power to fuse seems probable since red bulb does not light when fuse is removed. Your suggestions confirm this possibility so next step will be to look at distribution box connections. Thanks
BurbMan
Noblesville, IN
Posted: 12/12/20 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Check the ground at the fixture...typically the neutral wire is just pop riveted to the tin metal on the back of the fixture and corrodes easily. Common issue with tail lights also. Lack or ground in the circuit would prevent that "fuse out" light from working normally.
SOLD: 2002 Lance 811 Slide-In Camper
2002 Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
CharlesinGA
South of Atlanta, Georgia
Posted: 12/12/20 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
The red fuse warning light will NOT illuminate if there is no load on the circuit. You have a wire disconnected or broken.
Charles
hpdrver
Mansfield, Texas
Posted: 12/13/20 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Checked power to fuse and it shows 12v power. Next I checked light and 12v power is going to one side of switch but does not show any 12v power to the other side of switch when switched on.
If I am checking this correctly, the switch is bad so fixture needs to be replaced. Would this bad fixture cause the problem with the red fuse light not coming on when fuse is removed? Thanks
 > Light Problem
