RV.Net Open Roads Forum: Class A Motorhomes: Antifreeze no longer pink
 > Antifreeze no longer pink
DrewE
Vermont
Posted: 12/13/20 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
The dye color can fade, but so long as the bottle is sealed, there's no way for the antifreezing components (ethanol and/or PEG) to escape. I wouldn't have any qualms about using year-old discolored antifreeze, assuming of course it doesn't seem like there's something slimy growing in it or it's otherwise obviously bad and not merely faded.
rlw999
Washington State
Posted: 12/13/20 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have a year-old bottle of RV antifreeze and its color didn't fade, so I don't think I'd use a bottle if it did fade given the expensive consequences if it doesn't work as expected.
magicbus
Nantucket Island, MA
Posted: 12/13/20 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Tom_M wrote:
Put some in your freezer and see what happens. RV antifreeze can freeze but will not expand. It will likely turn to slush.
Why guess. This test will tell you all you need to know. I keep RV antifreeze from year to year and never saw it fade, but a simple test is better and cheaper that replacing something that probably is still good.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
cavie
Posted: 12/13/20 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
throw it away and spend $5.00 on new.
olfarmer
Iowa
Posted: 12/13/20 11:26pm Link  |  Quote  |  Print  |  Notify Moderator
I am with everyone that said buy new, not worth the risk for what it costs. I am curious though because I winterized my MH a year ago and haven't used it. I hope the antifreeze is still good!
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
olfarmer
Iowa
Posted: 12/13/20 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
double post deleted
* This post was edited 12/15/20 09:50pm by olfarmer *
Wherever I happen to park
Posted: 12/14/20 05:09am Link  |  Quote  |  Print  |  Notify Moderator
I recall a thread oh. perhaps 12-15 years ago somneone asking if he could use ENGINE type antifreeze instead (NO by the way)
I ask why At the time Engine stuff was like 8.00/gallon
Pink stuff on sale at ACE. hardware 1.00/gallon
Home is where I park it.
ItsyRV
Desert SW
Posted: 12/14/20 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
Monkeyman_and_Lady wrote:
I'm about to winterize my rig. I go to two of the gallons of antifreeze I've had since last last year. Unopened, but the pink colour is gone.
Is this stuff still okay to use?
If it's a Chemworld product they don't usually add the pink color to it. Just be aware it's a concentrate, so dilute to label specs before using in the system. Most people will add some food coloring just so they can see when it runs through the system and when flushed out.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
Blaster Man
Posted: 12/17/20 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Color of coolant is irrelevant. There are too many variables....for gas engines, for diesel engines, standard, extended life, probably more, and they don't mix well.
2014 American Eagle
