RV.Net Open Roads Forum: Tow Vehicles: New version of Ford's 9.75" axle?
Search only in Tow Vehicles
 > New version of Ford's 9.75" axle?
Groover
Pulaski, TN
Posted: 12/15/20 07:10am Link  |  Quote  |  Print  |  Notify Moderator
TFLtruck is reporting about a 3/4 float version of Ford's 9.75" axle for the F150 as something new. I know that the 9.75" axle has been around for ages but other than that I have no familiarity with it. Is this version actually something new? I have noticed in that through the 2020 model the highest tow ratings were not available with the 3.73 gear ratio that is often associated with the 9.75" gears but that changes with the 2021 model. Is this related?
TFLtruck really doesn't seem to know much about it other than it is holding up deliveries.
TFLtruck on 3/4 floating axle
BurbMan
Noblesville, IN
Posted: 12/15/20 08:12am Link  |  Quote  |  Print  |  Notify Moderator
So a 6-lug full floater? One more step to making the 250 unnecessary...maybe the marketing guys are moving toward eliminating the 150/250/350 lineup and just having 2 models, light duty and super duty. Would that be a bad thing? Most folks post here that the only difference between the 250 and 350 is the rear spring pack.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
ppine
Northern Nevada
Posted: 12/15/20 08:20am Link  |  Quote  |  Print  |  Notify Moderator
F-350 comes with a 10.5 inch diff.
Dana 60 in the front.
dodge guy
Bartlett IL
Posted: 12/15/20 08:51am Link  |  Quote  |  Print  |  Notify Moderator
If it’s what I think it is, it may be similar to the old Jeep Grand Cherokees where the bearings and seals were pressed into the axle shaft. This is the same design the 9” used and the old Chrysler 8 3/4, although those had a drop out center section.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JIMNLIN
Oklahoma
Posted: 12/15/20 09:09am Link  |  Quote  |  Print  |  Notify Moderator
looking at the design in the clicky shows the 3/4 full floater uses ball bearings instead of tapered roller bearings like a HD full floater.
Having come from the era when ball bearings were much in use on those old cars and light duty trucks I would pass on having them on my truck.
Granted ball bearing have much less rolling resistance than roller bearing but at what cost in long term reliability.
Monterey, California
Posted: 12/15/20 10:39am Link  |  Quote  |  Print  |  Notify Moderator
"One more step to making the 250 unnecessary...maybe the marketing guys are moving toward eliminating the 150/250/350 lineup and just having 2 models, light duty and super duty."
All depends on sales volume. Possible.
carringb
Corvallis, OR
Posted: 12/15/20 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Looks like the variant they’ve been using on the Transit.
2014 ORV really big trailer
2015 Ford Focus ST
4x4ord
Alberta
Posted: 12/15/20 11:19am Link  |  Quote  |  Print  |  Notify Moderator
Ball bearings can be reliable. There is an old power generating station in a ghost town named Sandon located in the Selkirk Mountains of BC. 17000 feet of wooden pipe brings water down the mountain feeding a turbine that has been running for over 100 years. It used to provide power for the town and a old nickel mine but now is tied to the grid. The shaft joining the turbine wheel to the generator is supported by the original wet ball bearings that have yet to require replacement. I suppose dirty gear oil might not provide the same level of lubrication.....
2021 F350 SRW Platinum short box 4x4.
B&W Companion
Groover
Pulaski, TN
Posted: 12/15/20 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
I was an engineer for Timken for nearly 20 years so I know a little about bearings. A properly installed taper roller bearing can carry more load in a given space but is more likely to be damaged by dirt or misalignment. I have seen both enjoy long lives or suffer short lives depending on how they are installed and taken care of. I have also seen ball bearing outlast tapered roller in industrial applications were there is a lot of dirt and alignment is difficult.
BenK
SF BayArea
Posted: 12/15/20 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with everyone and add :
The old 3/4 ton Suburbans (GMT400) had the same AAM axle assembly as the 1 ton dually of the same year. Only difference is in the leaf spring pack/hangers/brackets and the brake cyclinder/MC
Why parts counter will ask how wide your GMT400 3/4 ton Suburban has....there two and the difference is in the width of the shoes and drum. The wider shoe/drum also is a full floater rear end.
As for ball bearings vs rollers vs tapered rollers is that the balls have a smaller contact point with the race. Therefore lower rolling resistance
Rollers have a larger contact point and has a higher load rating vs a ball, but in regards to dia, the roller is rated to carry more
Tapered rollers has a much higher axial thrust load rating. Straight rollers almost none and balls has some.
Been advocating tossing the marketing nomenclature (1/2-3/4-1 ton, 150/250/350, 1500/2500/3500, etc) for years and just go with their GVWR. If they toss the 3/4 a step in the right direction, IMHO
-Ben Picture of my rig
