RV.Net Open Roads Forum: Truck Campers: Newbie Question About Tie Downs
 > Newbie Question About Tie Downs
ppine
Northern Nevada
Posted: 12/16/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
For larger campers, and longer trips you want tie downs that bolt to the frame.
TxGearhead
Posted: 12/16/20 11:44am Link  |  Quote  |  Print  |  Notify Moderator
You could save some money by using hardware store turnbuckles. I'm not talking about some light duty household turnbuckles. Look for some with 3/8" or 1/2" threads. You will need to attach them to the camper tiedown eyes with maybe a shackle. Use good size chain to go from the turnbuckle to the truck tiedowns. Then save your money for Torklift Fastguns.
I don't know how heavy your camper is. I would ask for comments from other members about using stake bed hold downs. Probably not for off road use though.
edit add: The Brophy tie downs may be what I'm referring to as stake bed tiedowns.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
moonlitsouls
Everywhere
Posted: 12/16/20 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
I’d rate them in order from best on down:
Torklift
Hapijac
Brophy.
And those are basically the only options I’m aware of.
As said, you have a very popular model of truck, should be able to score some used mounts if you keep your eye out for some. That would be the best low budget alternate save for making your own.
ok thanks, im going to have to go with the brophy if i cant find a used set asap
moonlitsouls
Everywhere
Posted: 12/16/20 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
ok thats good to know, i have a 4x4 truck , F350 long bed. The rig is going to be over 4k wet. And yes, i do want to be able to travel off the beaten path without worry. Im going to call brophy myself and keep asking around
Posted: 12/16/20 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Personal opinion, newer truck beds are pretty lightweight. I honestly wouldn’t tie a camper to the top of them. I’ve bent a lot of newer truck beds doing far less.
If you’re strapped for cash, can you make some?
2017 Heartland Torque T29
deltabravo
Spokane, WA
Posted: 12/17/20 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Torklift Frame mounted are what I'd use on a camper as big / heavy as an Eagle Cap.
JohnJM
Wycombe PA
Posted: 12/17/20 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Ive used Happi jacks for 20 yrs. Lots of time bouncing around on the beach. Never had a problem.
John M
moonlitsouls
Everywhere
Posted: 12/17/20 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
ok i shelled out the cash for the torklifts with the fastguns , hurt my wallet bad
Posted: 12/17/20 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
If your budget is tight why did you spend money on the fast guns?
d3500ram
Colorado
Posted: 12/17/20 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
You won't regret it.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
