RV.Net Open Roads Forum: Best way to clear grit and sand out of 7 pin plug??
 > Best way to clear grit and sand out of 7 pin plug??
schlep1967
Harrisburg, PA
Posted: 12/17/20 07:24am Link  |  Quote  |  Print  |  Notify Moderator
pigman1 wrote:
Duhh? Take it apart, wash thoroughly with soap and water using a toothbrush to get in crannies, rinse and let dry and put it back together.
Duhh? Not all of them come apart. Some are molded together at the factory.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
RCMAN46
NorthWest
Posted: 12/17/20 08:14am Link  |  Quote  |  Print  |  Notify Moderator
I would suggest first blow out as much as possible with air.
Next submerge in Simple green without diluting it. Leave in the Simple green for several hours or if you have the time a full day.
Next blow out the simple green with air then use hot water to remove the rest of the Simple Green. Then blow out with air until completely dry.
As stated get a cover for the plug when not is use. I found one at my local NAPA Auto Supply. 7 way rubber boot
hornet28
Muskegon Mi.
Posted: 12/17/20 09:40am Link  |  Quote  |  Print  |  Notify Moderator
I use one of these it works great.
https://www.reese-hitches.com/products/7_Way_Plug_Storage_Box,P-320
hornet28
Muskegon Mi.
Posted: 12/17/20 09:41am Link  |  Quote  |  Print  |  Notify Moderator
I use one of these to keep it clean and dry it works great.
profdant139
Posted: 12/17/20 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Lots of great suggestions here -- thanks! I never would have thought of washing it out with water, but of course the connections get wet in the rain. So water should be ok.
And obviously, I will try dry methods (vacuum and air compressor) first. Then water. The let it dry and blow it out some more.
The screwdriver idea makes sense -- I can insert the blade gently to open up a gap so the grit can be blown out.
I am reluctant to try WD 40 -- I'm worried that it will trap more grit.
Someone suggested taking the unit apart -- it's a one piece molded item and can't be disassembled.
I've done a lot of off road towing, and I have never seen so much dust and grit in my equipment as we experienced in the Mojave Desert. Wow!! Might be a good idea to wrap some plastic around the 7 pin next time we go there, as suggested above.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Bill.Satellite
Full-timer
Posted: 12/17/20 10:23am Link  |  Quote  |  Print  |  Notify Moderator
You can clean with WD40 but as you suggest it would then attract more debris. I like to use WD40 as the cleaner and then use a dry silicon spray to clean out the WD40! You end up with a nice dry clean connection.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 12/17/20 10:47am Link  |  Quote  |  Print  |  Notify Moderator
SPRAY strong soap. Wait overnight then blast with water hose nozzle. Been there don that
goff1256
Montrose Co
Posted: 12/17/20 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
Don’t get too carried away with this just wash it when you go to the car wash keep it simple unless you just need something to do
Erick & Jackie Goff; Plus Ellie Mae the Fu Fu Dog
profdant139
Posted: 12/17/20 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Well, this was one of those "easier than it seems" projects. First, I fired up the shop vac with a crevice tool. A little dust came out, but there were still grains of sand that were visible, trapped in the "female" prongs of the seven sockets.
Next, I fired up my air compressor with a narrow tipped air blower attachment. Bingo! I was worried that the stream of air would drive the sand grains deeper into the sockets, but nope. Out they flew.
My guess is that the air jet created back pressure within the body of the socket, blowing the grains of sand outward. (And no, none of it got in my eyes.)
Since that was so successful, I checked out the "male" fixture on my truck. It, too, was sandy. A few moments of compressed air, and it was clean as a whistle.
Someone above suggested "why bother cleaning this?" Maybe it's just my ultra-cautious mindset, but my response is that having sand and grit inside an electrical connection can't be a good thing. It'll interfere with the on-the-road performance of the seven pin assembly, and it'll abrade the components.
Plus, to be honest, what else have I got to do? Maintenance on my rig is always more fun than doing chores around the house!! [emoticon]
Alan_Hepburn
San Jose, Ca, USA
Posted: 12/17/20 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
WD 40 was designed to displace water on Electrical connections (WD=Water Displacement) So a very very good suggestion.
Close - it was actually developed as a rust prevention and degreasing product for the aerospace industry, and used as a coating on the outer skin of the old Atlas missiles. You can read all about it on the WD-40 website
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
