RV.Net Open Roads Forum: General RVing Issues: Receiver Bike Racks
 > Receiver Bike Racks
Page of 6
docsouce
Seekonk Ma.
Posted: 12/17/20 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I'm looking for advise on which receiver bicycle rack to buy. I have a 2020 Jayco 26XD Class C. It will be for 2 bikes. I searched and found a "CURT 18085 Tray style" which looked good but had some not so good reviews. So I figured the best info I can get is here with people that use them as I would. I would rather not use a ladder mounted type.
2020 JAYCO 26XD
Just right for the two of us!
way2roll
Wilmington NC
Posted: 12/17/20 06:48am Link  |  Quote  |  Print  |  Notify Moderator
I love Swagman racks. Easy to mount the bikes, modular for various types of bikes and overall well built and easy to use. I am an avid cyclist and my bikes can run thousands of dollars. Been trusting Swagman racks for years and zero issues. No I am not affiliated with them at all, but I have worked in bike shops and know what's out there. Dollar for dollar swagman racks are my top pick.
willald
NC
Posted: 12/17/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Whichever one you get, read up on it carefully before you buy. Make sure it is one that is supported/recommended to be used on the back of an RV.
For a lot of the hitch mounted bike racks out there, the manufacturers do not recommend it to be used on the back of an RV for various reasons. Last time I looked into this, there was only like 2 or 3 units made that would allow it to be used on the back of an RV.
Agree 100% with you about ladder mounted bike racks. Not a fan of those at all.
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis
See it here
jkwilson
Indiana
Posted: 12/17/20 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Swagman makes the Dispatch, Escapee and E-Spec that are good racks that are RV approved.
I have a Dispatch and carry two bikes on the back of our 5th wheel. I can see the handlebar of one bike in the camera, and it never even quivers. The drawbar is threaded and it bolts to the receiver so there is no movement.
I added lights to my rack. I felt like two bikes made it difficult to see the trailer lights from some angles. Just powered them with a trailer plug.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Gonzo42
California
Posted: 12/17/20 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Hollywood makes an excellent rack which can be refigured for different bikes
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
camp-n-family
London, Ontario
Posted: 12/17/20 08:24am Link  |  Quote  |  Print  |  Notify Moderator
None of them will be good unless they are secured tight in the receiver so they can't sway and bounce around. Slack in the receiver is what causes most problems. Best solution I have found to this is to drill a hole in the bottom of the receiver and weld a large nut over it. Then thread a bolt through it that you can tighten against the racks draw bar when installed. The bigger the nut and bolt the better. Takes all the slop out of the hitch and makes for a solid rack. Helps to prevent theft too. Hope the explanation makes sense, I don't have any pics to show.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
MikeDupont
TX
Posted: 12/17/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
We've happily used various Yakima racks for years, tho not in a RV hitch.
IAMICHABOD
Sunny So Cal
Posted: 12/17/20 08:37am Link  |  Quote  |  Print  |  Notify Moderator
I use the RV ApprovedSwagman Traveler XC2 Bike Rack mounted in my 2 inch receiver on the rear of my Class C.
Very happy with it,easy to load.
As for the bouncing that others have talked about to make it less pronounced You need a good anti rattle device so you don't get so much play in the receiver,thus magnifying the movement and doing any damage to the bike rack.
I have tried almost every Anti Rattle device on the market, most have been no good or so complicated and cumbersome that they are useless. Including the Roadmaster type, or blue ox totally useless.
Until I found the one at Hitch Rider.
Their Hitch Vice is the best and easiest one I have come across and it really works.
Former El Monte RV Rental
Buying A Rental Class C
magicbus
Nantucket Island, MA
Posted: 12/17/20 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Our Yakima hitch comes with this built in and it makes a big difference. We have the swing away model because we need to easily get to our rear doors, probably not needed for a class C.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
way2roll
Wilmington NC
Posted: 12/17/20 09:20am Link  |  Quote  |  Print  |  Notify Moderator
I should add that both Swagman racks I have owned had threaded pins and hole in the hitch itself so there is no slop. It's very solid. No aftermarket device needed.
Page of 6
