RV.Net Open Roads Forum: Fifth-Wheels: Slider
 > Slider
ventrman
Mission, TX
Posted: 12/18/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hi. I have a 2006 Dodge Cummins Diesel. It is a short bed Truck. Is there another type oh Hitch I can use I can use other than a slider?
God Bless!
MFL
Midwest
Posted: 12/18/20 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
If you get a sidewinder (turret) type pin box, you can use most any standard hitch.
Jerry
ventrman
Mission, TX
Posted: 12/18/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Where can I get a sidewinder?
C Schomer
Pueblo West, Co.
Posted: 12/18/20 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
If the loaded fiver pin weight is below the loaded truck payload you could mount the hitch a little behind the axle. A friend does that with no problem
RobWNY
Jamestown, NY
Posted: 12/18/20 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
ventrman, Reese makes the Sidewinder. I have the one with the air bag included. They are very nice. I got mine from the dealer I bought my 5th wheel from but you can get them from any reputable RV place including etrailer.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
cummins2014
Utah
Posted: 12/18/20 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Andersen Hitch, I tow with a Ram short bed , no clearance issues .
JIMNLIN
Oklahoma
Posted: 12/19/20 06:15am Link  |  Quote  |  Print  |  Notify Moderator
pullRite
Check out the PullRite super lite at around 50 lbs. Similar design as the Andersen hitch.
cummins2014
Utah
Posted: 12/19/20 10:59am Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
pullRite
That would certainly be a great option, I prefer the Andersen only because I wouldn't have to get up into the bed to lock the handle like on that PullRite. The locking handle on the Andersen attaches to the pin box, and can be accessed from the rear of the truck, without having to get into the bed . Reached from just standing on the ground.
Njmurvin
Simi Valley
Posted: 12/22/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
X2 (only mine is in a Chevy)
With the right pin box clearance to side rails and bed, the Andersen can give you approximately 9" more distance from the cab.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
ventrman
Mission, TX
Posted: 01/03/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
Can you post a picture of the hitch so I can get the right one? Thanks.
 > Slider
