RV.Net Open Roads Forum: Fifth-Wheels: Slider
 > Slider
Shal36
Winter Springs, FL
Posted: 02/13/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
mikeb9550 wrote:
For you guys with hitch conversions such as Anderson, Pullrite, etc., don’t you worry about having your rig towed by a tow truck due to a breakdown?
No, because I can remove the adapter in about five minutes. I’m an AUH user.
cummins2014
Utah
Posted: 02/13/21 11:12am Link  |  Quote  |  Print  |  Notify Moderator
And I carry the tools necessary, that is not an issue. Some have tried to make it some kind of drawback with the Andersen. Yes a five minute job .
cummins2014
Utah
Posted: 02/13/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Some forget there is an adapter on the kingpin using the Superglide that has to be removed in order to use a conventional hitch. I’ve also heard of them even being tack welded on , creating a bigger issue .
 > Slider
