RV.Net Open Roads Forum: Fifth-Wheels: Slider
 > Slider
ventrman
Mission, TX
Posted: 01/03/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Can someone post a link for the anderson hitch?
God Bless!
MFL
Midwest
Posted: 01/03/21 11:43am Link  |  Quote  |  Print  |  Notify Moderator
This is the Andersen for rails, the only version I'd recommend. It is available many places, but can be seen, ordered, and reviewed at E-trailer.
Jerry
ventrman
Mission, TX
Posted: 01/03/21 11:49am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Jerry. I appreciate it.
MFL
Midwest
Posted: 01/03/21 11:57am Link  |  Quote  |  Print  |  Notify Moderator
You're welcome!
ventrman
Mission, TX
Posted: 01/04/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I have been checking out Anderson hitches. The have 3 models. There is the gooseneck mount, the toolbox model, and the rail mount model. Which model is recommended? I already have a gooseneck hitch ball.
cummins2014
Utah
Posted: 01/04/21 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Then that would be the one with the gooseneck connection . What kind of weight are you towing ? I have the rail mount steel version . I already had the frame adapter that goes to the OE puck system for another hitch that took the standard rails . I would recommend the rail mount ,but you would need bed rails if you don't already have them. The one pictured above is the one I have. Wouldn't tow with anything else after having the Andersen , having towed with both conventional ,and the Andersen
* This post was edited 01/04/21 12:20pm by cummins2014 *
ventrman
Mission, TX
Posted: 01/07/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I will be towing a Forest River Sierra 5th Wheel. It weighs just over ten thousand pounds. I think it is 10,010.
cummins2014
Utah
Posted: 01/07/21 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Great candidate for the Andersen fifth wheel hitch . Mine is rated for 20K .
ventrman
Mission, TX
Posted: 01/21/21 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
I purchased an andersen hitch. I just got it today. Now I am waiting on the bed rails so I can get it installed.
Durb
NW
Posted: 01/22/21 09:04am Link  |  Quote  |  Print  |  Notify Moderator
When installing the Andersen adapter make sure the ball mount adapter on your kingpin is facing forward for additional cab clearance.
 > Slider
