RV.Net Open Roads Forum: Fifth-Wheels: DRV height
 > DRV height
Hobo2
Brooksville
Posted: 12/18/20 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2016 DRV 38RSSA does anyone know the exact height. Looking a an rv lot with open shed roof but have to get under 13.1 header
CA Traveler
The Western States
Posted: 12/18/20 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Measure it. One way is a 2x4 with a level on the high RV area and measure to ground.
2014 Grand Cherokee Overland
Bob
TXiceman
Full Time RVer
Posted: 12/18/20 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
Measure as per above with it hooked up to your truck. On a typical DRV, you will find them generally 13'-3" to 13'-6".
Ken
Amateur Radio Operator.
ford truck guy
Pennsylvania
Posted: 12/18/20 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
They are all different when hooked up to back under... YOU NEED to measure to get the proper answer
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Owens River Road area, north of Mammoth
Posted: 12/18/20 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Always important to take your own measurements...carefully I suggest.
MFL
Midwest
Posted: 12/18/20 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, measure it, but just looking online, at that model 13' 1". You will have to sand 1/4 inch off that header! [emoticon]
Jerry
CA Traveler
The Western States
Posted: 12/18/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Raise the roof if you are the owner.
dapperdan
Milwaukee
Posted: 12/18/20 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2015, same model. Your trailer is at least 13' 2", pretty much guaranty that's the minimum. We had 2" risers put on two years after getting our trailer due to the difference in bed height of our new (than) truck. Our trailer sits closer to 13" 4" now. DON'T guess, like others have said take a straight edge and level and measure to be sure, you don't want to find out the hard way! [emoticon]
This is how it should be done. BTW this is NOT our trailer!
Dan
Cummins12V98
on the road
Posted: 12/18/20 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Dan!!!
I have 3” risers and I an exactly 13’-4”
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
handsome51
Baytown
Posted: 12/18/20 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
make sure you measure from the top of the AC unit to the ground
 > DRV height
