Hobo2
Brooksville
I have a 2016 DRV 38RSSA does anyone know the exact height. Looking a an rv lot with open shed roof but have to get under 13.1 header
CA Traveler
The Western States
Measure it. One way is a 2x4 with a level on the high RV area and measure to ground.
2014 Grand Cherokee Overland
Bob
TXiceman
Full Time RVer
Measure as per above with it hooked up to your truck. On a typical DRV, you will find them generally 13'-3" to 13'-6".
Ken
Amateur Radio Operator.
ford truck guy
Pennsylvania
They are all different when hooked up to back under... YOU NEED to measure to get the proper answer
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Bishop area, California
Always important to take your own measurements...carefully I suggest.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MFL
Midwest
Yes, measure it, but just looking online, at that model 13' 1". You will have to sand 1/4 inch off that header! ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Jerry
CA Traveler
The Western States
Raise the roof if you are the owner.
dapperdan
Milwaukee
We have a 2015, same model. Your trailer is at least 13' 2", pretty much guaranty that's the minimum. We had 2" risers put on two years after getting our trailer due to the difference in bed height of our new (than) truck. Our trailer sits closer to 13" 4" now. DON'T guess, like others have said take a straight edge and level and measure to be sure, you don't want to find out the hard way! ![doh [emoticon]](http://www.rv.net/sharedcontent/cfb/images/doh.gif)
This is how it should be done. BTW this is NOT our trailer!
![[image]](https://i.imgur.com/lQd9BSgl.jpg)
Dan
Cummins12V98
on the road
Hi Dan!!!
I have 3” risers and I an exactly 13’-4”
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
handsome51
Baytown
make sure you measure from the top of the AC unit to the ground
