RV.Net Open Roads Forum: Fifth-Wheels: DRV height
 > DRV height
Cummins12V98
on the road
Posted: 12/19/20 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
Cummins12V98 wrote:
JRscooby wrote:
You might get 2-3 inches from tires. But don't want to leave it set with tires that soft.
Might think about building something like the converter used to pull second of a pair of semi trailers. For walking speed/short distance a plate with hole would work for 5th wheel.
Back in until close to hit, allowing for lift as unload TV. Unhook, push dolly under pin, and lower. Hook dolly to bumper hitch, lift legs, back on in. Put weight on legs before unhook.
Newer DRV's have a flat roof.
Looking at the picture, I see things sticking up from the roof.
Most semi trailers have flat roofs, but when hooked to a tractor the front is higher than rear. I bet the same applies to 5th wheels.
Mine is slightly higher in the front because my hitch is at it's lowest setting and I don't have room to raise the inbox.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
NJRVer
NJ
Posted: 12/19/20 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Hobo2 wrote:
I have a 2016 DRV 38RSSA does anyone know the exact height. Looking a an rv lot with open shed roof but have to get under 13.1 header
What is the header made out of? Is this the gable end or is the header carrying the rafters?
If it is 2x12's, take it out and replace it with a flitch beam. You could probably downsize it to 2x6's.
bucky
Raleigh metro
Posted: 12/20/20 03:19am Link  |  Quote  |  Print  |  Notify Moderator
What is the ground surface at the entrance. Is it something that can be scraped down. A pic of the structure would help.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Hobo2
Brooksville
Posted: 12/20/20 04:32am Link  |  Quote  |  Print  |  Notify Moderator
we Like the great outdoors resort in titusville,fl. There are several shed roof RV lots at 150,000.00 that my DRV would fit under. When i was younger we had a slide in camper that we would drive out on the beach at cape hatteras NC. we would run 15 lbs of air in the tires and go anywhere in the soft sand. There all aluminum building bye the way. The market is hot here with all the NORTHERN tax and spend city dwellers moving here. After 5 years of full timing were looking to park our rv at a nice resort for 6 months a year and have a place close to our kids.
NJRVer
NJ
Posted: 12/20/20 07:32am Link  |  Quote  |  Print  |  Notify Moderator
So if it is all aluminum, it's just one of those open walls with a metal roof on top that they sell? Basically a cover to park under?
If that is all it is, raise up the all the support posts to increase the height.
Allworth
Orlando, FL
Posted: 12/20/20 11:46am Link  |  Quote  |  Print  |  Notify Moderator
You can gain about two inches by deflating tires on the trailer. Pump them back up after you are under the header.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
larry barnhart
wenatchee. wa usa
Posted: 12/20/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
My first thought was what you said but not seeing something makes it for a hard decision to give.
chevman
chevman
2021 Jayco Hawk 28RL
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
 > DRV height
