RV.Net Open Roads Forum: Tech Issues: Powering a electric winch
 > Powering a electric winch
Slownsy
Posted: 12/18/20 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
My 2015 F350 diesel comes with 2 batteries, not sure how they are connected, so to connect winch to only 1 or run cable to both? Max draw about 400A.What says the gurus.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
agesilaus
North Florida
Posted: 12/18/20 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
They are in parallel I believe not split.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
RJsfishin
Winston Or.
Posted: 12/18/20 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Just hook it to one or the other,it'll be hooked to both
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Bill.Satellite
Full-timer
Posted: 12/18/20 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
2 6V batteries configured for 12V or 2 12V setup for 12V?
If 2 6's you MUST use both to power the 12V winch (an assumption). If 2 12V you "could" wire to only one battery but that would still not be the recommended setup.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
June Lake area, California
Posted: 12/18/20 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
You need a pro to guide you IMO.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 12/18/20 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
00 Cable is fine. The group 65 batteries are paralleled from the factory. Ford does not provide a big enough cable to the frame for ground. You'll have to make your own.
rhagfo
Portland, OR
Posted: 12/18/20 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Finally a correct answer! Diesels require more cranking power. They have two 12 volt batteries connected in parallel. You only need to connect to one set of terminals.
Slownsy
Posted: 12/18/20 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
Ok thanks to you all and a merry Christmas.
Frank.
2oldman
NM
Posted: 12/19/20 08:43am Link  |  Quote  |  Print  |  Notify Moderator
I say a 400a draw is ridiculously big for any battery or cables, if that's what you're actually drawing. Things will heat up, fast. I have a 120v winch I run with a generator. Works fine.
time2roll
Posted: 12/19/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
I have a MileMarker hydraulic winch. Main power comes from the power steering pump. 1 amp relay to activate. Can be used continuous with no heat issues.
675w Solar pictures back up
