RV.Net Open Roads Forum: Tech Issues: Powering a electric winch
 > Powering a electric winch
RJsfishin
Winston Or.
Posted: 12/19/20 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
A 400 amp draw is the Maximum draw under full load which seldom if ever would be used. And if it ever is, it may not be continuous duty if it heats up. Some times common sense has to be used, ya think ???!!!
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Slownsy
Posted: 12/22/20 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Actually rated as max 430 A 17000 lbs winch Sherpa Stead not rated continuous. Thanks for the comment regards op grading earth cable
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 12/22/20 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Snatch blocks are used to x torque by dividing line speed. A junk tire with a ½" chain makes an excellent deadman in the desert. A 36" flat blade screwdriver will help level wind incoming cable.
Slownsy
Posted: 12/23/20 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Mex.
Frank.
PastorCharlie
NC
Posted: 12/23/20 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 12,000 lb. WARN winch on my F350 diesel dually and I connect both cables ( Positive and Negative ) from the winch to the Positive and Negative battery on driver side.
I leave the Positive cable attached and attach the Negative cable when I use the winch. Plans are to install a battery disconnect.
I also have 3, 12,000 lb. snatch blocks and an extra 65 ft. cable for complicated pulls.
Slownsy
Posted: 12/29/20 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Ok did a bit of research re op grating wire on som older F trucks, not really clued on electric, when said to op grade earth what exactly should be done, heavier cable from batteries to frame ? Or batteries to alternator? Or both. What size cable, I read that people use one size smaller than positive? Why. If running 2/0 to winch I am also considering running a extra 2/0 cable between batteries positives, god idea or not, and also do I want to include fuses on cable, if so what size considering the load could be op to 430A and I think cable rating about 500A?
Thanks Frank.
MEXICOWANDERER
Posted: 12/29/20 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
Ford OEM used garbage grade cables so replacements are a good idea. Running negative ground 2/0 cables directly from negative battery post to winch motor itself is also a good idea because stuff bolted together is not guaranteed excellent like stuff welded together.
In the last 25 years I have made 20+ sets of DLO 2/0 cable with lead coated cast copper fittings for Ford diesels. Soldered terminals, and cable negatives from both batteries to engine cylinder head then from there to a SOLDERED cast lug on the frame rail with bolt and nut. This is a forever fix. I kept track of many for over a decade. DLO insulation does not rot like the original. I used Red heat shrink on the positive lugs. Group 65 batteries are notorious fume spewers.
With Ford's adopting the ND gear reduction starter back peddling to 1/0 cable is fine. A stackable single ½" diameter stud is fine for cable junctions. Use stainless steel nut lock and flat washer and keep the nut tight as hell. Gobbing silicone grease all over exposed terminals is an excellent idea. One again to make it clear I use pure lead coated cast copper lugs. Not tin coated. Pure lead. Crimped then soldered. Cables like this must be purchased in components then assembled yourself.
time2roll
Posted: 12/29/20 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
I would not be that worried about the ground because I would connect the power cables direct to both positive and negative terminals.
Possibly look for space to add some additional battery.
675w Solar pictures back up
MEXICOWANDERER
Posted: 12/29/20 11:07pm Link  |  Quote  |  Print  |  Notify Moderator
Some premium grade group 65 batteries have almost 900 CCA. That and a custom mount 200 amp alternator can drag a vehicle a long way through sand or snow. Winch manufacturers could use a 15 HP ND gear reduction big rig motors on their largest winches I wonder if that's not the case here?
whjco
Lexington, KY
Posted: 12/30/20 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Bill.Satellite wrote:
2 6V batteries configured for 12V or 2 12V setup for 12V?
If 2 6's you MUST use both to power the 12V winch (an assumption). If 2 12V you "could" wire to only one battery but that would still not be the recommended setup.
He stated that it was a diesel. It will have two 12vdc batteries connected in a parallel configuration.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
