RV.Net Open Roads Forum: Can you put diesel oil in a gas generator?
 > Can you put diesel oil in a gas generator?
map40
Posted: 12/18/20 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
So, can you?
Alfa SeeYa
Life rocks when your home rolls
chuckftboy
Fleming Island, Florida
Posted: 12/18/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
If you mean engine oil, the answer is yes.
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Bill.Satellite
Full-timer
Posted: 12/18/20 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
If you mean diesel fuel in a gas generator, the answer is no.
If you are talking about the engine oil, it's always better to use the specific oil recommended by the manufacturer.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
Monterey, California
Posted: 12/18/20 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Please clarify what you are asking.
grldst
Dallas, GA
Posted: 12/18/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have run Rotella 15-40 (T4) in everything from my lawn mower to a 15 liter diesel without any issues. Usually diesel motor oil will have more detergent in it then oils that are recommended for gas engines.
wopachop
Who run bartertown
Posted: 12/18/20 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
Not only is it OK some guys who build engines for a living will recommend it.
I run Delo 15/40 in my Onan genny.
Tom/Barb
Oak Harbor, Wa
Posted: 12/18/20 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
My ONAN is a diesel Kobata, it takes the same oil as my Cummins.
* This post was edited 12/18/20 09:10pm by an administrator/moderator *
noteven
Turtle Island
Posted: 12/19/20 10:19am Link  |  Quote  |  Print  |  Notify Moderator
Yes in the recommended multi-viscosity for all the temperatures you plan to cold start it in or high temperatures you will run it at high loads.
The viscosity for temperatures will be shown in your manual.
Engines experience a high % of their wear from cold start to close to operating temperature - lubrication is critical on cold start.
lenr
Indianapolis, IN
Posted: 12/19/20 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Diesel oil has additives specific to diesel engines including specific to the catalytic converter used on automotive diesels. Rotella now makes oils for gas engines with different additives.
valhalla360
No paticular place.
Posted: 12/19/20 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Check the oil spec for the generator...as long as you choose an oil of equal or higher standard, you will be fine.
Diesel oil is typically holds a higher end spec and will cause no problem in a generator. The other way around usually doesn't work.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
