RV.Net Open Roads Forum: Tech Issues: Electric space heaters
 > Electric space heaters
Page of 7
Bert the Welder
Van. Island
Posted: 12/19/20 10:23pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
theoldwizard1,
I think the brand name was something like "tempertek" for the electric heated carpets.
Found it!
https://www.tempurtechmanufacturing.com/
Do you have foam board or reflectix under your bed?
We put 1" blue foam board under our mattress. Wow, what a difference!!
I ask as, if putting a heat pad under the mattress, insulation under it would put more heat to the side you want it on.
* This post was edited 12/19/20 10:35pm by Bert the Welder *
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
rhagfo
Portland, OR
Posted: 12/19/20 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
Bert the Welder wrote:
pianotuna wrote:
theoldwizard1,
Found it!
Mattress pad heaters go on top of the mattress, not under it. They are just under the sheets.
Bert the Welder
Van. Island
Posted: 12/19/20 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Ah.
Well, the foam board under the mattress will still make a difference and worth doing. I'm talking from a TC perspective, anyhow.
pianotuna
Regina, SK, Canada
Posted: 12/20/20 02:53am Link  |  Quote  |  Print  |  Notify Moderator
Bert,
I have a thermostatically controlled 600 watt heater in my waste tanks enclosure. They are under the bed, so I'm not too concerned about insulation.
I do have a heated mattress pad--and highly recommend them for cold winter nights. My battery bank is sufficient to run them all night.
From a TC point of view, yes insulation under the mattress may be useful. One would have to make sure that the surface didn't drop below the dew point.
Regards, Don
Bumpyroad
Virginia
Posted: 12/20/20 06:09am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
I would avoid digitally controlled heaters. If the power "blips" they may turn off.
thanks, I didn't think of that.
but at least they wouldn't blink "12:00" [emoticon]
bumpy
Dave H M
IL
Posted: 12/20/20 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Lots of discussion here. [emoticon]
I only use ceramic heaters that have a tip over switch, easy to check to make sure it works.
Also have added separate wiring and plugs that hook up to the 15 amp outlet on the pedestal.
How easy is that?
Curly2001
Tucson, Arizona
Posted: 12/20/20 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I was also thinking about a heat strip in the A/C. We had an old Terry that had a heat strip and it was really good. Was old enough that we didn't have duct work but came out of the bottom of the A/C unit. Took the chill off and you didn't run the furnace. Do they still make them?
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
Bumpyroad
Virginia
Posted: 12/20/20 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
Curly
since they put out so little heat, much is lost if you have to heat up ductwork, etc. of limited value.
bumpy
coolmom42
Middle Tennessee
Posted: 12/20/20 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
Bumpyroad wrote:
coolmom42 wrote:
I've always just used the basic little cube style heaters. They go to 1500 watts and 2 different fan speeds.
Don't use them with an extension cord or plug strip. Check that the tip-over cutoff works. Set them in a place where they wont' get pushed against anything cloth or plastic. They are perfectly safe.
I will add, don't set them on the floor next to the bed as they can scorch a circle on the blanket when/if it comes in contact. [emoticon]
bumpy
Sounds like the voice of experience! I always make sure they are on a hard surface away from combustibles, both in the RV and at home.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
pianotuna
Regina, SK, Canada
Posted: 12/20/20 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
Heat strips are useful down to about 40 f. If it is cold than that the air conditioner fans don't like it.
Page of 7
