RV.Net Open Roads Forum: Travel Trailers: waterproofing slide floor
 > waterproofing slide floor
bamaboy
Cedar Creek, TX
Posted: 12/19/20 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I just had my 12 ft slide floor replaced due to water damage and it was pretty expensive. Does anyone have any suggestions on how to waterproof the new floor? inside especially which means no flexseal type products which arent healthy for indoor use.. I've read a ton of Articles and not really found a satisfactory suggestion.
TT is a 30 ft Coleman which I live in full time.
GrandpaKip
Flat Rock
Posted: 12/19/20 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Depends on what the new floor is made of.
If you have to stay in it, whatever you use will just about have to be water based.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
bamaboy
Cedar Creek, TX
Posted: 12/19/20 08:46am Link  |  Quote  |  Print  |  Notify Moderator
It's plywood. I'm hoping someone can share some experience good or bad with specific products.
jdc1
Rescue, Ca
Posted: 12/19/20 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Go to any tile store, Home Depot or Lowes and get a gallon of waterproof material like Aquadefense. Roll it on, then put your new carpet down.
colliehauler
Mc Pherson KS USA
Plywood will already be a lot better then OSB. You could use a outdoor spar varnish. Usually the water wicks into the wood from the edges and not the top or bottom.
bamaboy
Cedar Creek, TX
Posted: 12/19/20 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Since the new floor is already installed, any suggestions on how to get to the edges to seal them?
coolmom42
Middle Tennessee
Posted: 12/19/20 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
First thing I would do is caulk around all the edges, joints, etc that you can get to. Use Dicor non-levelling. Then a good quality exterior water-based polyurethane like Varathane It's not cheap but you don't need tons. Check the caulking and possibly reapply the poly annually.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Sjm9911
New Jersey
Posted: 12/19/20 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
How did the water damage occure to begine with? From inside? Usally the floor is pre treated at the factory and no sealant is recomended? Did you use marine grade plywood or normal? If just sealing the top paint or varnish it. I wouldn't do both sides. The idea is that the wood breathes and drys out on its own. My knowlage is based on pop ups ( bed slides) and my TT with a bed slide. But they never recomended sealing the wood, that was a big no no.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
bamaboy
Cedar Creek, TX
Posted: 12/19/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
unfortunately the water damage occurred while I was having emergency brain surgery in Florida in the middle of a pandemic, followed by 2 months of f radiation and chemo. While I was stuck in Florida the RV was home in Texas with the slide extended when a big storm apparently hit. The good news is the surgery and subsequent radiation and chemo turned out very well. But by the time I got home the floor was rotted out. I was thinking that if I had waterproofed the floor the damage wouldn't have been as bad.
I appreciate your comments about not sealing the floor. That makes sense.
I will tell you to be thankful for what you have. When you are a 20 year old you feel invincible. When you are 65 and one emergency surgery and a few hours away from death, you get a new appreciation for the things that are important.
coolmom42
Middle Tennessee
Posted: 12/19/20 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
Glad you have recovered!
