RV.Net Open Roads Forum: Ideal RV space size for new park?
Search only in RV Parks, Campgrounds and Attr...
Open Roads Forum  >  RV Parks, Campgrounds and Attractions
 > Ideal RV space size for new park?
Page of 5
wapiticountry
Mountain West
Posted: 12/19/20 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
California and the local authorities will have dozens of regulations and requirements relating to the construction of the park. Those will likely dictate the park layout. Among the things that will need to be addressed is the layout and location of any septic treatment plant, the construction, size and layout of the roads including turning radii as well as entry and exits to allow for emergency vehicles. There is likely requirements as to how far away some services can be from the sites (in my state a site without a sewer hookup cannot be more than 300 feet from a restroom). There will also assuredly be subdivision laws that will govern number of sites per acre and minimum separation between pads.
Once you clear the government, you will have to consider slope and drainage of the property. You may have requirements of fencing, of setbacks from boundaries, setbacks from roads etc. Only then can you start planning sites.
as a practical matter, to work with most all RVs a minimum of about 60 feet in length, with 75 more desireable. Widths less than 30 feet are generally considered close together. If you are looking primarily at long term workers you will also need to consid the space nedded 2nd vehicles and work vehicles.
Oasisbob
Portland Oregon 97266
Posted: 12/19/20 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Pull through spots are nice. We camp with a hybrid trailer and hate staying close to others due to noise. I would say space between spots is the more important factor. Depth for long rigs including TV is important. Didth 60 plus width is good. There is a balance between acreage and number of spots I realize. Good luck. Making those spots spot on level is also a huge plus. Thanks for asking
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
rlw999
Washington State
Posted: 12/19/20 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
I would design with all sites as pull through.
I'd rather back in and have nothing behind me but trees.
garyemunson
Reno, Nevada
Posted: 12/19/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Put hookups in the center of the "run". This way spaces can be utilized as "buddy" spots where RVs can pull in alternate directions to put door sides together. The one pulling in "backwards" hooks up by pulling utilities under their RV.
SDcampowneroperator
South Dakota
Posted: 12/19/20 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
First is to contact your state and national associatoins. CampCal Now , and ARVC Do not even think of building a camp without the guidance of these regulatory bodies helping you.
NHPA guidelines are not law, are helpful in design.
to answer your simple questions, Less is more. The expansion in size, of RVs (yes a trailer is an rv) demands more space, L x W so less units will occupy your land, but at lower cost and demand on utility.
Trends today with slides and awninggs demand a minimum of 40' width post to post, with todays 45' MHs and 5ers with tow and toys mean that with disconnect , unload 80' is the mean length of a pull through
Site sizing at this time is the foremost of your issues, I would say that 5 acres is not enough to open enough sites to make it a profitable venture.
cavie
Posted: 12/20/20 03:46am Link  |  Quote  |  Print  |  Notify Moderator
When you get further into this, especially in CA, the coast of permit and design work will scare the bejesus out of you.
Locations and # of electric pedestals are controlled by the NEC. The cost of electric service alone will probably put a stop to the whole thing. I know two people who tried it.
Better off to buy an existing park and remodel it.
cavie
Posted: 12/20/20 06:31am Link  |  Quote  |  Print  |  Notify Moderator
F5Park wrote:
great input, thank you.
My location is not a destination location. We are too far from I-5 to jump off and stay the night. The other parks in the area cater to more longer term RVs/5th wheels. I see the need for more longer term folks with the option for
less than 5 day campers. I am planning for at a minimum, 50,30,110 power50/30/110 power, level spots, maybe 30'x60' with back-in parking around the perimeter and pull-through in the middle. trying to limit 10 sites/acre. pet space, small play area, future to include bathroom, shower area. picnic table per site, fire rings not allowed at this time.
laundry and large grocery store less 2 miles away.
river access is less 2 miles away.
FYI 50 amp is 240 volts AC.
GDS-3950BH
DC
Posted: 12/20/20 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Pipe Dream: : an illusory or fantastic plan, hope, or story.
profdant139
Posted: 12/20/20 10:22am Link  |  Quote  |  Print  |  Notify Moderator
This is slightly off topic, but it deals with design issues: make sure that the sewer openings for each site are as low as possible.
We have stayed in a few parks where the sewer opening at the site is several inches above ground level. This makes it hard for the guests to fully drain their waste tanks, leading to an increased chance of spillage.
Yes, the guests can compensate for the bad design by using sewer hose supports (that's what we do), but that means that the RV park owner is gambling on the competence of the guests.
Good luck with this whole project -- I wish you well! There is a huge need for long-term space (especially in the hard-hit Butte County area). What a hard time it has been for you.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
wapiticountry
Mountain West
Posted: 12/20/20 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Building and sanitation regulations will require a minimum clearance bove the ground. This is to prevent runoff from infiltrting the sewage treatment system.
Page of 5
