RV.Net Open Roads Forum: General RVing Issues: Running CPAP Without Utilities
 > Running CPAP Without Utilities
ppine
Northern Nevada
Posted: 12/20/20 11:00am Link  |  Quote  |  Print  |  Notify Moderator
A motorcycle battery will work.
A friend brought his CPAP on a week long canoe trip.
edatlanta
Maplesville, AL Home Base
Posted: 12/21/20 06:01am Link  |  Quote  |  Print  |  Notify Moderator
mowermech wrote:
We both are on CPAP. When dry camping in the motorhome, we run the machines on 12VDC. The two T-105 house batteries will run both machines overnight with no problems. We don't mess with shutting down the humidifiers.
During the day, I run the generator long enough to recharge the batteries, run the AC, use the microwave, etc.
It works for us.
Only one CPAP here and my two T105's don't even show a reduction in charge overnight and I use the humidifier and a heated hose. My usual 1 hour generator run in the mornings for coffee and a little TV tops the batteries off again. Works for me.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Geobiker
California
Posted: 01/02/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for the info. Some good stuff. Looks like I have some options to investigate. Thanks again.
dennis1
Seattle, WA
Posted: 01/03/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
I use a battery pack from the same company that makes the CPAP. Hooks directly to CPAP. Cost was $200. Lasted about 2 nights, then I charge it up with my generatotor. Next I purchased a GOAL Zero 400 lithium generator. I c@n run my CPAP 5 nights. Cost was $500. Plus I can use the Goal Zero for other thing# also. If you use a lead acid battery be aware of the gas that is discharged when you charge it and also very heavy. Lithium battery weight 10% of lead acid. I purchased a 50aH Battle Born lithium battery and it weighs 17 pound. I will run my CPAP FOR 5 days. Cost $525. Lithium battery do not discharge ant gas when charging. Battle Born batteries are guaranteed for 10 years. The best lead acid battery May run 3-4 years.
My new DRW and camper on the truck the first time.
rlb8s
Yorktown, VA
Posted: 02/13/21 04:56am Link  |  Quote  |  Print  |  Notify Moderator
Will something like this work? Jackery Explorer 290
12 RoadTrek 210 Simplicity - named E-Pod
05 GMC 3500 SRW Crew Cab LB
10 Bass Cat Puma w/ 250 Mercury ProXS
Previous RVs -
14 Livin Lite 8.6
13 Pleasure-Way Lexor TS Class B
13 Tioga Montara 25K Class C
09 Lance 915 Truck Camper
CharlesinGA
South of Atlanta, Georgia
Posted: 02/13/21 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
Durb wrote:
My son uses a Jackery 1000 for his Dream Machine. It uses 6% of a full charge for one night. He also has the optional portable solar panel to charge it. He has a cigarette lighter type power cord that plugs right into the 12V Jackery port.
I was going to suggest a Bluetti, I knew there were others but could not remember the names, Jackery is quite popular. They are expensive but some of the larger ones would run the CPAP and an electric blanket for days on end, especially if you used a portable solar panel to top it off during the day.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
