RV.Net Open Roads Forum: Tech Issues: whirlpool washer balance
 > whirlpool washer balance
badboy368
OHIO
Posted: 12/20/20 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I just installed a brand new whirlpool stackable washer and dryer. I am happy with the performance of both so far, but the washer literally shakes the entire coach when spinning. Has anyone ever experienced this or know what i can do to maybe balance this machine? Or maybe point me in the right direction to solve this?
40' pusher,350 turbo cat, pullin a 37' trailer haulin a drag car. oh yea baby
opnspaces
San Diego Ca
Posted: 12/20/20 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
When my home washer does this I pause the washer and redistribute the load around so it's more uniform.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
coolmom42
Middle Tennessee
Posted: 12/20/20 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure the coach is level and the washer is level in the coach.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Posted: 12/20/20 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
The washer empty will not shake.> but even my mini can really shake things up (1.6 CU-Ft does bedding by the Johnny Cash Method "One Sheet at a Time" [emoticon] )
re-arrange cloths and re-start spin cycle.. You may need to do this a few times.
Cummins12V98
on the road
Posted: 12/20/20 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
That’s what they do. “L” clip it to the floor.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
coolmom42
Middle Tennessee
Posted: 12/20/20 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
That assumes the floor is level. It's not a good idea to transfer all that vibration stress to the floor.
Cummins12V98
on the road
Posted: 12/21/20 07:14am Link  |  Quote  |  Print  |  Notify Moderator
That is exactly how both my washer and dryer were installed at DRV.
badboy368
OHIO
Posted: 12/21/20 07:41am Link  |  Quote  |  Print  |  Notify Moderator
coach is definitely level, and washer is level also. i will try pausing the cycle and rearranging load to see if that helps. this surely has me puzzled. Please keep any other ideas coming
RJsfishin
Winston Or.
Posted: 12/21/20 07:50am Link  |  Quote  |  Print  |  Notify Moderator
you doing too big a loads Make them smaller then its easier to distribute the load evenly
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
dougrainer
Carrolton, Texas
Posted: 12/21/20 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Did you REMOVE the drum shipping bolts? Forgetting these usually causes your problem. Doug
