billtex
RI
Interesting. Do you also have the snow plow package on your truck? The heavier springs would help.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
valhalla360
No paticular place.
billtex wrote: Gadwall,
I am curious as I never used Sumos.
Are the Sumos longer than the OE front bumpstops?
We put a set on the back of our 2008 F250.
The OEM bumpstops are not intended to come into contact unless you bottom out the suspension. In normal use, they should never come into play.
The Sumosprings go in their place and are significantly taller (I believe it was 7" vs 3").
When installed on ours, the suspension has to compress about an inch before they come into contact and they are progressive (at first they provide little support and then it ramps up as you compress more). This means when lightly loaded, they don't feel as harsh if you do hit a bump.
They did come with an optional spacer, so they would always be in contact even when lightly loaded and thus provide more (not necessarily better) support.
We chose them over air bags as there is basically nothing to fail. The downside is you can't adjust on the fly but we are towing not carrying a truck camper. Installation is easy, 1 bolt to remove the old bump stop (the biggest challenge if the truck isn't newish) and 1 bolt to put the new spring on.
Front coil springs are a bit different design and we didn't get those.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Busdriver
Shepherdsville Ky 40165
Have them on my truck & camper, I feel it helps the ride on both
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
Kayteg1
California > Nevada
Stiffening front suspension when you have heavy load on rear axle will worsen the handling.
Law of physics.
Kayteg1 wrote: Stiffening front suspension when you have heavy load on rear axle will worsen the handling.
Law of physics.
Yes and no. While I doubt the initial spring rate “needs” to be any stiffer, the camper could be adding load to an already-heavy front end.
Weight transfer when braking or when turning and the whole truck rolls to one side could be improved by sumos if set up correctly and at the same time, not affect initial spring rate.
It’s something I considered on the old truck as adding a heavier front sway bar, like any sway bar, also has its subtle disadvantages in handling by making a solid axle even more solid and the characteristics that come with that.
OP could report how it acts empty.
