RV.Net Open Roads Forum: Tech Issues: Flojet macerator: is it reliable? Maintenance issues?
 > Flojet macerator: is it reliable? Maintenance issues?
profdant139
Posted: 12/20/20 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
More great tips -- thanks! I especially like the idea of giving the impeller a little twist before each use. I wonder how I am going to remember to do that each time. A checklist will help -- I have a lot of those for a variety of situations.
But then, of course, there is the problem of remembering to check the checklist.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
ktmrfs
Portland, Oregon
Posted: 12/20/20 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
I have a portable (Which by the way I no longer have a use for. but that's a topic for elsewhere) over the 15 years I've used it. It always got the job done when I needed it. NOW understand I prefer the 3" stinky Slinky (Got one of those brand new as well) The ONLY problems I had with it are mostly SUE problems (SUE is "Stupid User Error")
1: on the portable there is a fuse in the bottom of the handle. .Yup. did not know it was there. Took me a while to discover it.
Two. the motor shaft extends all the way out what I call the "Bottom" of the motor (Pump is the top part) and there is a slot. If you have not used it for a few days take a flat tool. Like a quarter or a washer. And give the shaft a "Twist" in the direction suggested by the outlet. The impeller may (otherwise) stick, which is Why I had to find the fuse.
Once I figured out the "Twist the shaft" long long time no problems..
OH feed it well.. I ran 10Ga wire from teh fuse panel about 5 feet to a compartment where I terminated with Anderson power Poles (40 amp size) and plugged the Macerator line in there... Why Anderson Power poles.. I use a lot of them on my Radio gear and have 10Ga Extension cables and so on. So I had them. Are they better than other options? Very good question. but for me yes. Due to the fact I have a lot of stuff that pluggs into that port.
yup, right on for the fuse and avoiding the "stuck impeller" and wiring.
I dump at home, but have about a 1ft rise. Have used one for about 8 years, 20-30 times/year and it has been flawless.
2011 Keystone Outback 295RE
ReneeG
Meridian, Idaho
Posted: 12/20/20 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
You do have to pause operation of it after about 14 minutes or so, even with the water jet running, so that adds time to the dumping.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Lantley
Ellicott City, Maryland
Posted: 12/20/20 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have one and it gets the job done, but its slow and wiring can get hot. I have to keep an eye on it.
It work fine for what it is, however I only use it as a last resort
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
D.E.Bishop
Eagle Rock, CA
Posted: 12/20/20 11:50pm Link  |  Quote  |  Print  |  Notify Moderator
I made my own out of a garbage disposal. Here is a link...
LINK
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
Pipeman
Windsor, Ontario,
Posted: 12/21/20 05:19am Link  |  Quote  |  Print  |  Notify Moderator
I have one and when in a campground that doesn't have full hookups I pump into a tote in the bed of the truck and then go to the dump site and let gravity do its' job.......I sometimes will flush it with fresh water when we come home.
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
edatlanta
Maplesville, AL Home Base
Posted: 12/21/20 05:48am Link  |  Quote  |  Print  |  Notify Moderator
I bought one 10 years ago for use at a campground where I was going to host. The ranger told me over the phone the nearest dump location was 75' or so from my site and I could just use it. When I arrived I found the dump site was 205' from my site and I never had the nerve to try the pump. I could just see it quitting with 200' of poo in the hose. I have still never used it, but I take it with me every trip just in case.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
mbopp
Henrietta, NY, USA
Posted: 12/21/20 08:37am Link  |  Quote  |  Print  |  Notify Moderator
We'll camp for up to 2 weeks at a no-hookup campground. I use a Flojet to pump the tanks into a 30-gallon barrel mounted in the truck bed, and also for dumping at home. I made hoses from 3/4" corrugated pond or water feature hose since it's light, coils easily, and there's no back pressure on it.
I've had the pump for 12 years or so and had my first issue. Short story - several blades broke off the impeller and jammed the pump. I took the front of the pump off and managed to fish the blades out the discharge port. There were 2 blades left and that let the pump function enough to get me through the week. Flojet is a variation of a Jabsco pump so I ordered a Jabsco replacement impeller. Flojet says to use a 9/32" ignition wrench to hold the shaft while you unscrew the retaining nut but I clamped a large screwdriver in a vise and used the slot on the end of the motor shaft to hold it while I unscrewed the nut. Other than that it's a simple replacement.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
profdant139
Posted: 12/21/20 09:44am Link  |  Quote  |  Print  |  Notify Moderator
9/32?? What an odd choice by the designers -- not a quarter or five-sixteenths? Very few standard wrench sets include a 9/32 wrench.
Oh, well. If I ever have the need to do that repair, I'll use your workaround!
hotpepperkid
Kingman AZ
Posted: 12/21/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
I have no problems with mine. I only us it when I return home for a trip to really clean things out. I get every thing all hooked up get my chair and a couple of beers and flush away
2019 Ford F-350 long bed SRW 4X4 6.4 PSD Grand Designs Reflection 295RL 5th wheel
