RV.Net Open Roads Forum: Towing: Towing with a dually or single?need help please
Search only in Towing
Open Roads Forum  >  Towing
 > Towing with a dually or single?need help please
Page of 6
loverving45
Canada
Posted: 12/20/20 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I have a 39’ fifth wheel 4 slides, , 14000 pound, and am about to buy a pick up to tow it. Everyone tells me to buy regular pickup , not a dually. They say the regular single rear wheel is enough for towing this fifth wheel and no need for dually. I’ve heard that dually is a must have for such big trailers due to the steadiness it provides. My question is for those of you who own similar size of rig, do you suggest me buying a dually or a single rear wheel? Also, which if the companies is the best for this purpose, ram, gmc or Ford? Any suggestion would be greatly appreciated and helpful. Thank you
BobsYourUncle
Calgary Alberta Canada
Posted: 12/20/20 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
My TT is only 32' and half the weight of your rig, but I love the extra stability the dually offers. Even in southern Alberta winds, which can be brutal at times, I find it very stable. 14,000 pounds is a lot of weight and my opinion is for the dually.
Brand? Doesn't matter, all the big 3 are up to the task. Pick the one that you like best. But I would definitely go diesel, not gas.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
Jack_Diane_Freedom
Burlington Ontario Canada
Posted: 12/20/20 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
I recently towed a 40ft, 14000lb Mobile Suites for thousands of miles with a F350 short box singe rear wheel. Did not ever experience a problem with stability, sway or anything else. Truck was V-10 gasser and more than up to the task. Just let it rev, that is where it works best.
2oldman
NM
Posted: 12/20/20 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
drw v srw 2019
Advantage/disadvantage dually
dually or no 2011
More dually w/5er 2011
Dually vs single 2014 in fivers
Dually vs single 2019 in fivers
Second Chance
Wherever...
Posted: 12/20/20 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Is 14,000 lbs. the empty weight or GVWR?
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
BB_TX
McKinney, Texas
Posted: 12/20/20 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
The tow and payload ratings of the trucks keep going up almost yearly. New trucks, SRW and DRW, are far more capable than just a few years ago. A newer single rear wheel (SRW) will be fine for that trailer. But check the ratings for the truck you are looking at. Depending on configuration the ratings can vary a lot for the same year, same model truck depending on cab, bed, engine, drive train, etc.
As far as brand, what YOU like best. All three are great, dependable, and capable trucks.
Walaby
Georgia
Posted: 12/20/20 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
My 5er is 13880 lbs and nearly 41ft length. Have no problems towing it with a 1 ton SRW. That said, I know many people who have towed large 5ers with both would tell you hands down the best towing experience will be with the DRW, and they are likely correct. But, Im happy with my setup, have never had any issues. Have experienced one panic stop in wet weather and never felt out of control in the slightest.
As others have said, brand is what you like best, but for a 5er in the 14K territory, IMHO, diesel is the only way to go.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Monterey, California
Posted: 12/20/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Driving a SRW without the 5er is much more pleasurable.
Posted: 12/20/20 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
What was said above.
Although I’ll add, the way you asked the question leads one to believe that you don’t have a lot of towing experience. And with that a dually will be better.....if it’s not a city daily driver the rest of the time.
2017 Heartland Torque T29
MitchF150
Puyallup, WA
Posted: 12/20/20 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hope you get the answer you are looking for.. [emoticon]
Mitch
* This post was edited 12/21/20 09:34am by an administrator/moderator *
Page of 6
