azdryheat
Tucson, AZ
39 feet and it's only 14000 pounds, really? Mine is 40 feet and 19,000 pounds. 16,500 empty.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
rhagfo
Portland, OR
Well there is a lot to be said about towing with a DRW, personally with our 32’ 5er running close to 13,000# and. 2,800# pin with the 1,400# of hitch, in bed tool box and DW and I we would have been within a couple hundred pounds of GVWR.
So much of it has to do with pin weight and what you carry in your truck.
To the many that I tow 16,000# with a SB SRW don’t know what they don’t know. They are likely well over weight, and as I have stated before The best feature of a 5er is it’s worst, that is their natural stability.
ReneeG
Meridian, Idaho
Our current FW was originally towed with an F250 V10 short box, SRW. We traded in for a diesel dually long bed F350 and so glad we did. More stable, more power for towing up AND down grades. Our FW is 13k fully loaded too.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Fstmvrerik
Salina, Ks.
I have pulled heavy fifth wheel campers and trailers for pleasure and work. The percentage of having a trailer hooked up to the truck has gone down to towing a trailer 3 or 4 times a month. I switched from DRW to a SRW one ton truck, the only time I miss the DRW is in high wind towing. I did worry about the safety factor of drive tire loss while towing, but got over that over the years.
IMO the convenience and cost reduction of the SRW (when not full time towing) make it the best choice for me.
SDcampowneroperator
South Dakota
We tow a 16k Fiver loaded weight with a second ( double tow) 2.5 k trailer. Gross 26k with a SRW 3500 extrended cab long bed. diesel.
No issues of stability, overloading, braking.
If a SRW is rated to do the job with pin weight, why is DRW justified? Not.
More important to handling is wheelbase.. A longer trucks wheelbase is the stability, not the extra tires, the springs and axles are the same.
Get over the length and parking issues of a long bed. Save yourself the cost of slider hitches, have the room for cargo or an extra fuel tank. Our 80 gal in bed diesel tank extends range 900 mi. more.
4x4ord
Alberta
It comes down to how much you will use the truck not towing. My fiver weighs 16k fully loaded and I don’t need or want a dually. If the truck was a dedicated towing vehicle I still wouldn’t need a dually but I might buy one for the added stability. If you’re buying new you would be thrilled with any diesel 1 ton SRW.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
SweetLou
La Quinta, CA USA
My dually tows 12K empty and we can fill the thing. I am very happy with the stability. As previously said on the pros, only cons are wider when empty, and two extra tires.
2013 3500 Cummins 6.7 Quadcab 4x4 3.73 68FE Trans, 2007 HitchHiker Discover America 329 RSB
We love our Westie
valhalla360
No paticular place.
Once again...is 14k loaded or empty weight.
You are at the border between SRW and DRW. If that's empty weight, you are in dually territory. If it's GVWR, a SRW of recent vintage is likely fine (check the ratings anyway).
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
rhagfo
Portland, OR
As I read these post about towing a 16,000#+ 5er with a SRW, I think about GVWR and axle ratings. Prior to 2020 both GM and Ford highest GVWR for a SRW was 11,500#, making the approximate max payload about 3,700#. Ram on the other hand the 3500 SRW LB had a GVWR of 12,300# since 2013.
One needs to ask why didn’t GM and Ford up their SRW GVWR in 2014 to match Ram. Best guess is that GM and Ford didn’t have the frame strength to make those increases.
ferndaleflyer
everywhere
I subscribe to the "you never have to much truck" idea. I got my first dually in 1985 and wouldn't dream of a SRW for towing. You get in a situation one time and all the reasons for not having DRW disappear. Once is all it takes. Its the rubber on the road that can save your life.
