RV.Net Open Roads Forum: Is there a more accurate way to measure fluid levels?
 > Is there a more accurate way to measure fluid levels?
obiwancanoli
Napa
Posted: 12/21/20 08:43am Link  |  Quote  |  Print  |  Notify Moderator
I'm not a big fan of the meters in my MH that show fresh, gray and black tank levels... They're hardly accurate, but I wondered if there's a better way... ?
ktmrfs
Portland, Oregon
Posted: 12/21/20 09:47am Link  |  Quote  |  Print  |  Notify Moderator
there are better sensor systems, but they aren't inexpensive. Seelevel system is what I have and it is very reliable. Garnet systems.
There is another external sensor system similar to the Seelevel as well.
Seelevel is easy to install and uses the existing wiring system, but can't be completely calibrated to acount for odd tank shapes.
the other system can be calibrated for odd tank shapes but is harder to install and IIRC doesn't use the existing tank sensor wiring.
2011 Keystone Outback 295RE
2oldman
NM
Posted: 12/21/20 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Not that I've found, other than getting a feel for when things are filling up. For instance, I know my gray is full when there's standing water in the shower. LOL
My fresh works pretty good.
shum02
Burlington ON CDA
Posted: 12/21/20 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
x2
When I'm standing in water in the tub the grey is full.
I grab a headlamp, never a flashlight, open the loo and have a look.
When both of those are full I am probably almost out of FW.
Even when the gauges worked, they never worked well.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
2oldman
NM
Posted: 12/21/20 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
I can smell the gray before the shower pan actually has water in it. I guess that's why black and gray are separate!
* This post was edited 12/21/20 12:57pm by 2oldman *
Heisenberg
West Texas
Posted: 12/21/20 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
A stick down the toilet is accurate.
2013 Winnebago Sightseer
2017 Colorado
bucky
Raleigh metro
Posted: 12/22/20 03:58am Link  |  Quote  |  Print  |  Notify Moderator
So what do you do with the stick after that? [emoticon]
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Wherever I happen to park
Posted: 12/22/20 04:56am Link  |  Quote  |  Print  |  Notify Moderator
There is. the SEE LEVEL system is one such method. I did not get around 2 it but from what I have read from folks using it it works well. The system consists of an elctronic strip that tapes to the outside of the tank and measures the level by electroinc means.. beyond that... I've not used one so that's all I know.
Home is where I park it.
Dutch_12078
Winters south, summers north
Posted: 12/22/20 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Another vote for the SeeLevel system. It's one of the first mods I make on each RV I buy. The accuracy and percentage readouts are a big improvement over the "Empty-1/3-2/3-Full" common OEM readouts, as are the external sensors that can't get shorted out by TP, etc..
Dutch
2001 GBM Landau 34' Class A
way2roll
Wilmington NC
Posted: 12/22/20 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Wonder if there is a way to integrate the see level into the one connect system. Our previous MH's had the standard lit gauges. Our new FW is all lcd on a screen with various menus etc and viewable on an app. Frankly it scares me. I know a lot of folks like shiny new techy things. Personally I think it's a way for a lot of stuff to go very wrong all at once.
