RV.Net Open Roads Forum: Fifth-Wheels: Six-point leveling system -- reduce rocking
 > Six-point leveling system -- reduce rocking
TenOC
On the road -- Full time
Posted: 12/21/20 09:33am Link  |  Quote  |  Print  |  Notify Moderator
We have a new to us 36-foot 5th wheel with a 6-point self-leveling stabilizer system. Our previous 5th wheel had manual stabilizing jacks equipped with the JT StrongArm stabilizers, and we really loved the strongarm stabilizers. When we had a travel trailer to reduce the rocking motion, we would manually crank up the stabilizing jacks to take some weight off of the springs and tires. I assume I could manually do much the same with the self-leveling 6-point system, but I have not figured out how yet.
This anyone have real life experience with the JT strong-arm stabilizers mounted to a 6 point self-leveling system?
Any other suggestions on reducing the rocking motion are very welcome.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
valhalla360
No paticular place.
Posted: 12/21/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Friends have them on their 6 point...doesn't look difficult. Just make sure to go around and release them prior to activating the system.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Super_Dave
Harrisville, UT
Posted: 12/21/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Are you asking from experience with the new 6 point? We have the 6 point and have no movement with no additions.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
Cummins12V98
on the road
Posted: 12/21/20 11:13am Link  |  Quote  |  Print  |  Notify Moderator
To reduce movement make some nice 3/4" plywood boxes as I made. The shorter the ram extends the more stable it is 24k setting on the 6 boxes.
Note tires not touching the ground.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ford truck guy
Pennsylvania
Posted: 12/21/20 11:20am Link  |  Quote  |  Print  |  Notify Moderator
show off ! [emoticon]
I use old 8" square lumber cut to 10" ..Like Rons stated above, the shorter those rams extend, the more stable you will be..
* This post was edited 12/22/20 08:04am by an administrator/moderator *
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
RobWNY
Jamestown, NY
Posted: 12/21/20 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Our previous 5th wheel only had the front landing gear and the rear stabilizer jacks. I used X-Chocks which did very little and I had a tripod on the king pin that didn't do anything either. Our new 5th wheel has the 6 point system and it's rock solid without any add-ons. I don't have wood blocks like others that have replied here but I use a whole stack of lynx levelers under each jack pad. I was pleasantly surprised how stable the rig is.
* This post was edited 12/22/20 06:11am by RobWNY *
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
Campinghoss@51
Windsor NC
Posted: 12/21/20 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Ours has the 6 point system and JT strong arms. Stable and not an issue.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
Cummins12V98
on the road
Posted: 12/21/20 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Take a trip out West and we can make you a set.
* This post was edited 12/22/20 08:05am by an administrator/moderator *
azdryheat
Tucson, AZ
Posted: 12/21/20 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
If you're using the common LCI system do the following once you have leveled your trailer: Turn on the control box. Scroll up or down till you find 'Manual Mode' and press enter. You can now manually extend the jacks to the height you need.
One other idea I incorporated on my toy hauler was adding scissor jacks on the extreme rear of the trailer to add stability when the rear garage/bedroom was occupied.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
Splashers3
Oakville, MD
Posted: 12/22/20 04:48am Link  |  Quote  |  Print  |  Notify Moderator
I used 6 x 6s about a foot long. I also added nice sturdy handles that make it very easy to carry them to and from my truck bed. I use these in order to reduce the chance of getting 6 pt leveling stoke error.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
