Pipsfc
Nevada
I went to add some air into my tires for my camper and noticed they were green valve stem covers. I remember someone telling me once that green caps usually indicate the tire is filed with nitrogen. Does anyone know if that's true? I can't seem to find anywhere in the manual where it talks about this.
Bumpyroad
Virginia
yep, filled with 100% nitrogen in place of 80%
bumpy
MFL
Midwest
Yes, that is what the green cap is indicating. However, not a big deal, just use air, which is mostly nitrogen anyway. It would be nearly impossible to maintain 100 percent nitrogen, even if available. For RV tires, it is mostly just sales hype!
Jerry
Pipsfc
Nevada
Ok... thought so. Wasn't sure if I had to keep using nitrogen or not, but you answered that question. Air it will be! Thanks!
StirCrazy
Kamloops, BC, Canada
Pipsfc wrote: Ok... thought so. Wasn't sure if I had to keep using nitrogen or not, but you answered that question. Air it will be! Thanks!
except you will lose the benifit of what nitrogen does.
if you fill with all nitrogen you will see slightly lower running temps, less pressure loss and it keeps the inside dryer.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Edd505
Elephant Butte, NM
yes like said above, add air as needed. High school science, air is nitrogen & oxygen 21 % oxygen, 78 % nitrogen.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
South of Lone Pine, California
I use 78.09% nitrogen at all times in all my tires. Breathe it too when under stress. Always have.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
wanderingbob
monticeeo, fla
As said many times before , there is no tubeless tire with 100 % nitrogen . Empty a tire and it is still full of air , all you can do is add nitrogen to the tire that is full of ambient air . A vacuum pump will not empty a tubeless tire . Jut add air and forget nitrogen .
wanderingbob
monticeeo, fla
Reminds me of the person on here whom said that he used a vacuum pump to get 100 per cent of the air out . Wow , the tire would collapse and loose the seal at the rim .
time2roll
Since O2 and the rest bleed out so quickly virtually all tires have just Nitrogen. Molecules are the same size so it must be some voodoo power of the green cap.
675w Solar pictures back up
