RV.Net Open Roads Forum: Travel Trailers: Green Valve Stem Covers
 > Green Valve Stem Covers
Guy Roan
Posted: 12/24/20 04:11am Link  |  Quote  |  Print  |  Notify Moderator
Boon Docker wrote:
Guy Roan wrote:
My new Toyota pick up has green valves and a few weeks ago the low tire light came on. I checked with my gage and sure enough all four wheels only had 25 PSI. I topped them off with my handy dandy little 12 volt compressor, and they never complained, and the green valves never changed to black, or purple, etc, so I guess all is well.
Guy
If I were you I would get those defective green valves replaced. [emoticon]
What color will be compatible with half nitrogen and half compressor air ?
Or should I just buy four new tires ?
Guy
time2roll
Posted: 12/24/20 11:17am Link  |  Quote  |  Print  |  Notify Moderator
No need for new tires. Just rotate the air/nitrogen between them to get everything equalized.
675w Solar pictures back up
Guy Roan
Posted: 12/24/20 11:51am Link  |  Quote  |  Print  |  Notify Moderator
No way !
At this age I'll have another senior moment - get the hoses mixed up and end up putting nitrogen into my air compressor
Guy
philh
Belleville MI
Posted: 12/24/20 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
ktmrfs wrote:
The vapor obeys boyles law, the liquid does not. That affects how temp changes affect tire pressure.
Again, for most consumer applications, it will not make enough difference to be signficant or affect operation.
Pull out the H2O phase diagram, it takes a lot of heat to begin having a meaningful impact on pressure. Boyles law falls apart with differences in temperature. In addition water vapor changing to pure gas is where you would see big pressure changes...
I stand by my statement, automotive tires will never see the type of temperatures that will cause steam.
philh
Belleville MI
Posted: 12/24/20 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
phil-t wrote:
Oh Oh! I purchased a utility trailer this past summer - it had green caps, i adjuste3d air pressure with my garage duty air compressor - am I liable to change those caps to some other color? Not! [emoticon]
try gold plated caps, you must be rich if you can fill your own tires with {shudder} air.
ktmrfs
Portland, Oregon
Posted: 12/24/20 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
like i said for consumer applications it will NOT make enough difference to be significant or affect operation!
Now if you care about fractions of a PSI variation like lots of racing operations do, then moisture is a uncontrolled variable. That's one reason they use dry air source, usually nitrogen because it's easy to come by. It doesn't take steam, just change in the amount of water vapor.
2011 Keystone Outback 295RE
Duane4238
North Tonawanda, New York
Posted: 01/13/21 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
I've aired down my tt tires at least a hundred times and then filled with Helium. I think I've got most of the old air out now because I had the trailer weighed and it's gone from over 7k lbs. down to just under 2k. I should now get about 150,000 miles out of a set of tires.
On the other side of the coin, I run my pickup truck tires at 300 lbs each. That way in the winter I have 1200lbs total and the extra weight helps with traction on the snowy roads here in Western New York.[emoticon]
Guy Roan
Posted: 01/14/21 04:12am Link  |  Quote  |  Print  |  Notify Moderator
Put some more helium in them, and you could end up with a radio controlled RV drone.
Guy
campigloo
Baton Rouge, La
Posted: 01/16/21 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
Diamond c wrote:
I installed an oversized blinker fluid reservoir so I con leave it on for lots of miles.
Man, must be nice to have that kind of cash. I have to do like most people, only use them when I might make a turn. Do you have this problem too, seems my left blinker comes on just before I turn right??
Huntindog
Phoenix AZ
Posted: 01/16/21 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
You haven't seen me drive!![emoticon]
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
540 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
